Kick Down Cable
Old Mar 13, 2006 | 09:10 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
Kick Down Cable
Any advice on replacing the kick down cable on a 88 IROC? I can see the bolt holding it on the tranny, but can't get a wrench/socket on it. Any special tool or maybe I'm going about it wrong.
I'm sure it's been covered, but we all know why I'm reposting the question
-Dan
Old Mar 13, 2006 | 09:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
maybe a socket and a ratchet with a bend-able head? or a swivel socket?
Old Mar 13, 2006 | 10:18 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
unbolt the crossmember and lower the trans so you can get a 10mm wrench or socket on it.
Old Mar 13, 2006 | 11:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yep, only way to get to it. Just make sure you remove your dist. cap and keep an eye on how close the dist. gets to the firewall.
Old Mar 20, 2006 | 07:01 PM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
Transmission: 2.77 700R4 Auto
Not true i did it without lowering it at all it took forever only being able to turn the wrench like a 1/8 turn at a time. and then having to flip it over then flip it back over etc. make sure you have the right size too
Old Mar 20, 2006 | 07:23 PM
dsherw00d's Avatar
I'm going to give this a try before this weekend. Maybe I can heat and bend a 10mm wrench to fit better - maybe like dizzy wrench. I think maybe I'll try it with a brake line 10mm wrench? If this fails, then I'll lower it. Hopefully it's not to tight or corroded.
Thanks,
Dan
Old Mar 20, 2006 | 08:01 PM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
well also make sure you have the right size for it by trying small sockets on it. mine wasnt what some people told me
Old Mar 20, 2006 | 09:05 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i just did it this saturday, used a small 10mm wrench. bit tricky, but worked. you'll have to drop the pan to hook the bottom of the cable, but i'm sure you already knew that. use a rubber tranny pan seal, works much better than the cork ones.
don't forget to readjust the cable after you install it! good luck!
Old Mar 20, 2006 | 09:08 PM
Shagwell's Avatar
Car: projects.......
...I've never had to drop the pan to hook the cable up.
Old Mar 21, 2006 | 01:03 AM
Pro Built Automatics's Avatar
This is a TV cable, not a "kick down cable". This cable is critical to the life of the transmission, and how it upshifts and downshifts, and must be adjusted correctly.
Old Mar 21, 2006 | 05:57 AM
dsherw00d's Avatar
Does anyone have the procedure to adjust it?
Thanks,
Dan
Old Mar 21, 2006 | 11:52 AM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
look on 700r4.com's website there is an article somewhere that is helpful their wrench size isnt the right size for mine but everything else is useful. you need two people in order to hook up the cable without dropping the pan
you need them to pull on the actual wire not the sleeve after you hook the hole of the transmission end on the paper clip like hook. after that they need to make sure there is constant tension on it as you lower it back down into the transmission or it will come unhooked.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
tattmann
Sep 27, 2015 05:20 PM
