700r4 problem
Old Mar 26, 2006 | 08:10 PM
iroc86z's Avatar
Car: 82 Z
Engine: 350 carb'd
Transmission: th-350
Axle/Gears: 3.08 posi
700r4 problem
ive isolated the problem in my 700r4 as being stuck in second gear. any ideas on wat could cause this? also i changed the filter and fluid today, and i found 2 small plastic pieces. any help is greatly appreciated. thanks
Old Mar 27, 2006 | 05:24 PM
iroc86z's Avatar
Car: 82 Z
Engine: 350 carb'd
no one has any suggestions?
Old Mar 27, 2006 | 09:45 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
your tranny only shifts up to scond or your are constantly in second?
Old Mar 28, 2006 | 03:00 PM
iroc86z's Avatar
Car: 82 Z
Engine: 350 carb'd
the car starts in second, and will not shift out
Old Mar 28, 2006 | 05:42 PM
87zjeff's Avatar
it's a good possibility that the plastic pieces are the washer that holds the reverse input drum off the pump stator. this would allow the reverse input to come out of place and put your 2/4 band in a bind causing you to start in 2nd. contrary to popular belief, shifting into 1st or second with the shifter doesn't mean the band applies. it is only applied in 2nd and 4th wether the tranny is shifting itself or you are manually shifting it.. sounds like your band is in a bind on the reverse drum.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
