4th gen rear in 3rd gen??
Car: 91 Firebird
Transmission: auto
I know this is a pretty staight forward swap, but just wondering if anyone who has done this has any pics of how far it will push the wheels out, I have been told 1.5 to 2 inch per side, but am curious to actually see the results before I decide what to do. Any help appreciated, thanks.
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
I want info too!!!
from what i have read on other thread it should be bolt on on my 1989 gta with rear disk brakes...but will calipers and disk brakes off my 9 bolt will bolt on to a 1994 camaro diff???
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
some pics here
https://www.thirdgen.org/forums/body...n-rearend.html
Search on front page does work - just takes patience.
Brakes? Many 4th gen rears have disk brakes already - I got a 2000 rear, now I have LS1 rear discs
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
i dont think its rubing.....but i got no good tire to test it ill know this summer with my slick. For the break, 9 bolt and 10 bolt have different backplate.
your 94 rear should come with pbr break ?
Seb
Seb
hey seb....
i just find out you are from québec...and right it with the ''é'' so i think you speak french dont you? where are you from in québec?
and about power break question well all disks brakes have no?
Car: Iroc-z 86
Engine: 350 4bbl
im from saint-eustache et oui je parle francais
pbr=aluminium galiper and not power break
my rear was coming with ls1 12" disk break your rear should come with lt1 11.xx disk break
maybe your galiper carrier from your 9bolt can bolt up to the 10 bolt but im not 100% sure
Merci beaucoup
::ws6gta.monchar.com Trans Am GTA WS-6 1989
tu mas surement déja vu a st-eustache moi ou mon chum aik son caprice blanc devant noir???
My calipers are made of aluminum...anyways me on a picture of my car on 1/4miles my tires diesapers in the fender flush to my 16inches mags...suspension 100% stock with moroso shocks street tires 2.02 0n 60feets. it should rub!
add me on msn fieldy__666@hotmail.com plz seb!
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
I fit ZO6 rear rims on mine with no spacers and a fourth gen rear. Tires line up like factory...
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
is it worth it to do this swap ?
I'm considering this swap myself but I'm going to run 400rwhp
how much power can 4th gen rear handle ?
can I use 95-96 Impala SS rear end or it should be Fbody to fit straight forward
Car: 1992 RS
Engine: Carbed 350
10 bolt rear is 10 bolt rear - 3rd gen or 4th gen, will all handle the same power in stock form - can also be beefed up the same if needed - welding axle tubes, etc. There is a tech article on beefing up the 10 bolt rear.
Car: 87 Z28
Engine: 383
Transmission: th350
is't the same rear that came on caprice ?
or the caprice rear are different and do they have Tq arm mount ?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only thirdgen or fourthgen rears have the torque arm mount.
Originally Posted by proxemics
so I should not bother my self looking for 4th rear
Car: 1992 RS
Engine: Carbed 350
I think the point is being missed - the ONLY rear swap you can make (without major welding/fabbing is a 3rd or 4th gen (Fbody) rear. I understand 9 bolt Fbody rears were stronger, but they are rare, expensive, and hard to get parts for (what I read). An Fbody 10 bolt rear can be made plenty strong enough with girdles and having the axle tubes welded all the way around - there is a tech article on it (tech articles on main page).
The advantage to a 4th gen rear is 1) many are already positraction, and 2) they have disc brakes. I paid like $250 for my year 2000 LS1 3.42 posi rear - That's a damned sight cheaper than the $400 for posi rear parts/gears and installation, and the $900+ cost of fabbing brackets and getting parts to have rear disc brakes.
Car: Iroc-z 86
Engine: 350 4bbl
same for me its more cost than durability.....my rebuilt was costing way more than a complete 4thgen rear and 4.10 gear install
i dont have big power for now but if it handle an ls1 it should handle my 225hp 350 smog engine
Seb
Seb
Car: 1992 RS
Engine: Carbed 350
As mentioned - the Caprice does not have the torque arm mount, so the rearend won't mount in an Fbod. The gears inside could be used, but why? You'll have to pay a shop to install, as this can't be done in the driveway (unless you have the right expensive tools, and plenty of rear end knowledge). Install of new gears and posi is not a simple matter of swapping parts - gears sets wear themselves into their environment, thus swapping any gearset means properly shimming to exact clearances - requires precision calipers.
If your going to have a rear built, then have new gears/posi installed - why spend all that installation money on used junk with an unknown history?
And the only true way to know if a rearend has posi, and what gearset it contains, is to take the cover off and look (count gear teeth).
Car: 89 Firebird
Engine: 355
Transmission: 700
Well the reason is good ole money. The 2 caprices i am talking about I can get whatever I want off of them.
If the gear sets are in the same series as mine and I reuse my gears, pinion depth wouldnt change so all i have to worry about is backlash. Am I thinking correctly?
Sorry about the hijack.
the newer body caprice's use an 8.5" 10 bolt not the f body 7.5. the boxy caprices were 7.5 though I believe...
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
