Which one?
Old Apr 9, 2006 | 04:42 AM
BKbandit's Avatar
Car: 86 camaro z28
Engine: 350 HO crate
Transmission: 5 speed
Which one?
I got a 350 ho and a 5 speed tranny(how can i tell if its a t5 or not, what do i look for) and i want to swap it for a auto. What should i do turbo 350 or turbo 400. The easyest, cheapest, best performing tranny(i noe thats alot to ask for).
Old Apr 9, 2006 | 04:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The T5 was the only 5 speed available.
Old Apr 9, 2006 | 05:26 AM
BKbandit's Avatar
Car: 86 camaro z28
thats good news, thanks
Old Apr 9, 2006 | 10:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The TH350 is the easiest, cheapest swap but not the best performing tranny. It just depends on what kind of performance you're looking for.
Old Apr 9, 2006 | 09:46 PM
BKbandit's Avatar
Car: 86 camaro z28
So what tranny should i be looking for. I dont want to really spend much. Some guys are telling me to just keep the t5 but it might be a pain in the nyc streets. The most horse i might have on the car(and this is a long shot) is 380 but regardless anything im playin with 400lbs of torque and up. What would u guys do.
Old Apr 9, 2006 | 10:06 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
a turbo 350 will handle that easily if built right and are easily found. you will need the b&m kit for the ta mount. iirc if you use a long tailshaft the driveshaft will fit.
Old Apr 10, 2006 | 12:01 AM
BKbandit's Avatar
Car: 86 camaro z28
how much im i lookin at with the 350 turbo and b&m shift kit. Will it just fit right in the place of the t5 or do i need to get additional parts?
Old Apr 10, 2006 | 12:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll need a console plate, shifter, shift cable, flexplate, torque converter, kickdown cable, and a few other things here and there.
