Clutch Question... (Did a search..)
Old Apr 10, 2006 | 08:45 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
I searched here on thirdgen.org for what kinda clutch I should get.. (still unsure) and posted this message on camaroz28.com (no replys..AGAIN still unsure which clutch)
Im new to this site.. First post obviously... The guys on thirdgen.org recommended I come here for to look for a clutch. I have a T56 Trans from a 94 Camaro. The engine (305 91 TPI) is mostly stock.. nothing special. One day I plan on doing a twin turbo setup.. its not gonna happen anytime soon (unfortunatly). My car is gonna be a "street/strip car." I see a lot of you guys recommend the McLeod Twin Disk clutch. Im sure its worth the 1000 bucks but is it worth it for a engine that pushs 250 hp (TOPS)??? Any advice?
Dan
Old Apr 11, 2006 | 10:32 PM
Can NO ONE help me??? Should I just go with a Centerforce DF and be done with it???
Dan
Old Apr 11, 2006 | 10:54 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
The OEM replacement would do fine for your current application, I've seen them hold up to 350hp with abuse and work fine.
Old Apr 12, 2006 | 11:49 AM
thanks for the info battman. Anybody else have opinions?? Nothing personal to you battman.. I just like to get a couple opinions and see what everybody says..
Dan
Old Apr 12, 2006 | 11:53 AM
Shagwell's Avatar
Car: projects.......
Yes, a good OE will hold more than the power you have. - That said, I'd still probably go with something like a CF or Spec stage I....
Old Apr 12, 2006 | 11:59 AM
whys that Shagwell??? Just personal preference?? (meaning why would you go with CF/SPEC) And when you guys say OE do you mean go to the GM dealer or a local auto part store? And yes I know that OE stands for orginal equipment.
Dan
Old Apr 12, 2006 | 12:17 PM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
For your current set up if you're spending more than $200 for your clutch disk, pressure plate, pilot bearing, and throw out bearing, you're putting money in the wrong place. Go OE unless you're putting out 350+ ft/lbs of torque.
Old Apr 12, 2006 | 12:27 PM
Yeah.. I agree with you (now) Bigdreams.. Last night I was thinking long and hard about it and came to the same conclusion as you.. Spending over 200 bucks for a clutch on pretty much stock motor.. it would be a waste..
Dan
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
