How many bolt is my rear axle
Old Apr 16, 2006 | 03:36 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's the stock 2.77 posi rear from an 86 trans am. No, it hasn't been replaced. No, taking the cover off isn't possible (well, not easy since I'm across the state). I'm looking at new gears so I'm trying to find what specs I'd need to know before ordering.
Old Apr 16, 2006 | 03:46 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
crawl under back of car, count number of bolts, then you have your answer, its that simple man
Old Apr 16, 2006 | 04:08 PM
Car: 86 T/A
Engine: HSR 355
I'm guessing its 9 bolt then, but like I said, its across the state so just crawling under is a 4 hour process.
Old Apr 16, 2006 | 04:13 PM
I-rocin's Avatar
Car: 87 iroc-z28
is there any member of your family that could look? you don't even have to jack up the car, an average person can slide under there and look
Old Apr 16, 2006 | 05:06 PM
ede's Avatar
ede
Old Apr 17, 2006 | 08:29 AM
Car: 86 T/A
Engine: HSR 355
My friend counted 9 bolts on the cover.
Old Apr 17, 2006 | 11:52 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
very simple question here.....is there a rubber filler plug on the cover...? if so it's a 9 bolt. if there is no rubber plug it's a 10 bolt.
Old Apr 17, 2006 | 02:54 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
well if im correct if its a 2.77 its a 9 bolt i think only the 9 bolt came with the 2.77 10 bolts had the 2.73. My 89 was 2.77 9bolt my buddies 89 was 2.73 10bolt and everyone else with 9or10 had those ratios. My 85 T/A had the 3.27 9 bolt which i swapped to my 89.
Old Apr 18, 2006 | 07:05 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Unless you are positive of what you have, I myself would not be ordering parts. More so if its a 2series 9-bolt, which parts may not exist. My opinion.
Old Apr 18, 2006 | 08:21 AM
Car: 86 T/A
Engine: HSR 355
Well I trust my buddy's ability to count to 9 so I don't see the problem. It does have a rubber filler plug so it's definitely a 9 bolt.
Old Apr 18, 2006 | 08:39 AM
1BADROC's Avatar
Car: 1989 IROC-Z
it will say borg warner on the bottom of the hogs head where the driveshaft connects just incase he cant count like the guy thinks
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
