posi Q's
Old Apr 22, 2006 | 09:54 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
posi Q's
how do i tell if a posi is functioning properly when it is out of the car, but still in the housing? would be a torsen unit if it matters.
Thanks!
Old Apr 22, 2006 | 10:04 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
got me on that one
Old Apr 22, 2006 | 11:29 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
if you spin one side, the opposite side should turn the other way, is that a good indication?
Old Apr 24, 2006 | 02:53 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
ttt
Old Apr 26, 2006 | 10:00 PM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
have a friend hold one wheel then you turn the other wheel forward and feel the amount of force to turn it. i have done this but i dont know the spec or how you would measure them.
Old Apr 27, 2006 | 02:56 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
k, that sounds like it will work
Old Apr 27, 2006 | 08:15 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
or you could go out and wait until it rain and spin the biatch...... Then again that's just the easy way lol.
You guys overcomplicate things.
problem with turning the wheels in the air is theres not much load on the tire your turning therefore even worn out posi's seem to look like they are in fine working order while doing that.
Anyways pull the rear diff cover or go burn some tires is the only real way to find out.
If the tires turn opposite directions or 1 side turns and the other doesn't it's open or a worn out posi.
Old Apr 27, 2006 | 08:27 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
That wont work on a zexel you will get 1 wheel spinning.
If its a zexel its helical and doest have much that can wear out. They are a good posi that never has to be rebuilt because it doesn't have a clutch pack.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
