G80 REAR ONLY SPINNIN ONE TIRE!!!
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
HEY GUYS IM HAVING TROUBLE WITH MY REAR NOW. I GOT MY NEW MOTOR IN AND I CHANGED THE REAR FLUID TO A MOBIL SYNTHETIC AND ADDED THE POSI ADDITIVE. NOW I WENT TO LIGHT EM UP AND ONLY SMOKED ONE TIRE. AS I TORE OFF THE OTHER STARTED TO SPIN A LITTLE BIT. ANY SUGGESTIONS WOULD BE GREAT. I HOPE ITS NOT THE REAR CAUSE AFTER THAT MOTOR IM BROKE. P.S ITS THE STOCK REAR OUT OF AN 85 IROC WITH 3.42 GEARS.
...yet another sythetic problem...
- the sythetic is slick, slick to the point that the clutches in your posi won't grab..... other wise, it's simply worn out....
Car: 85 IROC Z
Sorry bout the caps lock. Im at work and its always on. But do u think I should try and drain that fluid and refill with regular stuff? I know its a long shot but is it worth a try? Thanks for replying.
Car: 85 IROC Z
Well i changed the fluid back to regular fluid last night. Now its definatly not whining as much as it was. I didnt try to smoke them up yet but thanks for your help.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its not uncommon at all for people to think that if they put in some so called 'top of the line' synthetic oil and end up with problems like this.
These things are 20 years old and not designed for it!
hectre13
Dec 11, 2023 08:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
