Clutch selection time...
Old Apr 28, 2006 | 06:16 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I recently picked up a T-5 for my camaro.... i needa know what would be the best choice of clutch for me.
this is gunna be my first manual trans car and i want to do it right, im afraid with vehicle weight and my HP and Tq levels im burn a stock one up but you tell me
with my mods(see bottom) i should be at 350hp 400ftlbs at the crank(best estimate and dynosim) @ 3400lbs my car is no light weight
i plan on street/strip and i drive her hard all the time
Old Apr 29, 2006 | 12:40 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
TTT
Old Apr 30, 2006 | 08:26 AM
Pat Hall's Avatar
I've been eyeballing the Ram multi-friction unit with the kevlar/organic disc for my T5 setup. I run a Ram powergrip in my 69 camaro and it works beautiful. I've read posts from other board members saying they don't like the feel of the centerforce dual friction units, so you might want to stay away from those. The Ram units costs about $225. If that's a little steep for your budget, Zoom has a performance clutch for around $190 IIRC. Of course these are prices from Summit racing I'm quoting. Don't believe their box when it says "guaranteed lowest prices". Lol, what a load of B.S.
Old Apr 30, 2006 | 08:58 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I had put the Ram multi disc in a customers car a year or so ago and it's holding up well behind a WC T5. The engine dyno'd 520hp. The Centerforce DF units hold up well but have a stock feel to the clutch which is how they were designed. Instead of pressure plate tension that makes the clutch hold better and gives the pedal a firmer feel, they use the centrifugal weights to increase the pressure with RPM. So it holds real well but the clutch feels stock.
Old Apr 30, 2006 | 09:07 AM
Pat Hall's Avatar
Anesthes and a couple of other members said the centerforce units made the pedal feel way too low as far as engagement/disengagement goes.
Old Apr 30, 2006 | 09:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My Centerforce II is fine.
JamesC
Old Apr 30, 2006 | 11:48 AM
Barry 85IROC's Avatar
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
My centerforce is great. The transmission sucks. That's why I'm converting to TH-350.
Old Apr 30, 2006 | 09:43 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Cool Thanks.... im not overly concerned about clutch pedal because this will be my first actually 5spd driver( i have drive stick b4 although not for any substantial period) all i care about in the feel dept. is that there is some, i drove my friends RX-7 and there is no feeling to it at all.... you cant feel it grab, you let the clutch out slowly to get a feel for it engaging and the car is rolling already and bucking because of a lugged motor...
i know zoom has a ZVC variable clutch that uses inertia weights to increase clamping force while keeping a stock or "easy" feel to it.... seems nice but as long as its not like im driving a farm tractor i dont care
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
