4th gen rear end specs.
Old May 4, 2006 | 08:11 AM
1988350bia's Avatar
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
what are the 4th gen. rear end specs? and do you have to switch the master cylinder when swapping drums for disc brakes?
Old May 4, 2006 | 04:51 PM
ede's Avatar
ede
what specs do you want? 65 ft/lbs, 25 in/lbs, .008, 2.238", 3:42, or 56". there's lot of specs. not you don't need to change the MC.
Old May 4, 2006 | 05:38 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
i was wondering the splines, width of the comlpete rear end, all the gears available, which ones had posi, and anything else you think i'd need to know to swap them out and what to look for.
Old May 4, 2006 | 08:49 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
things to know... get a v8 one and its going to be 2 inches wider. bolts right up and you might need a prop valve if you dont have disc brakes already. gear specs will depend on what its out of.
Old May 5, 2006 | 01:35 AM
iroc22's Avatar
All Z28's and TA's had posi.
All 6 speed cars were 3.42 rears, auto's were 3.23 with G92 and 2.73 w/o G92
Old May 5, 2006 | 01:34 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
All 4th gen rears are the same length.
Old May 5, 2006 | 04:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The only true way to know posi and gear ratios is to take the cover off, look for the posi, and count the teeth. I read the 1997 and later models were a tad shorter in length, but not sure. Only need to swap the proportioning valve to use the rear discs effeciently.
Old May 6, 2006 | 10:54 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea i know thats what i was saying . i just made a run on sentence and worded it weird. LOL
I meant to say just get a v8 4th gen rear from a v8 and it will be fine. However they are 2 inches wider than our stock thirdgen rears. They bolt in without any modification except maybe the brake lines and e-cables. Since torsens never need rebuilding it should be good to go!
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
