7oor4 will not shift at high rpm's
Old May 8, 2006 | 09:32 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
Took the camro to the track the other day, only to find out that it doesn’t want to shift in to 2nd or 3rd gear at high rpm’s. It shifts fine when just driving in town or the highway however. I know it only a 700r4 but it still doesn’t shift when I let up on the pedal. I recently put in a b&m mega shifter, could that have messed up my shifting? Has anyone else had problems with there 700r4 not shifting and if so what did u do to fix it. The motor is a 305 whit hooker 2055, if that helps any…
Old May 8, 2006 | 11:40 AM
burn0ut305's Avatar
Car: z28
Well I talked to a mechanic today and this is what he told me. He said that I need new rear end gears, and that my old 2.?? Gears aren’t good very good, and are spinning so fast that they wont allow for the trany to engage in the right gears. He also said I should go with a 3.90 gears or higher in the rear end and that will help my shifting.
Ps I was doing a search and there was alto of talk about adjusting the TV cable. What is a TV cable and do I need to adjust it?
Old May 8, 2006 | 12:04 PM
Shagwell's Avatar
Car: projects.......
...you're mechanic just feed you a line of bull and is trying to bend you over. You're rear gears may be worn from age/mileage, but that has nothing to do with the trans shifting or not.
- two things: 1st being the TV cable adjustment, 2nd the trans governor.
You need to check that the cable is adjusted properly, then you need to match the governor weight to the rpm band of you motor.
Old May 8, 2006 | 02:29 PM
burn0ut305's Avatar
Car: z28
Well first off it wasn’t my mechanic, and I wasn’t going to get the gears put in by him so why would he fill me full of bull-****? It was actually one of the college professors at my college that teaches automotive classes, so I figure that gives him some credibility, and he use to be very big into drag racing. Anyway like I said b4 what the HE*L is a TV cable????? Also could you explain a little more about how to get the governor weight set at the right rpm band of my motor? These are probably common questions about the 700r4 so thank u so much for resonding.
Old May 8, 2006 | 05:57 PM
burn0ut305's Avatar
Car: z28
Ok well took the car to O-Reilly tonight and they readjusted my TV cable. It dint seem to help very much. Told them about the gear thing and they were like wtf who told you that, just like you did shagwell, so I’m guessing that’s not the problem. They pretty much suggested my tranny is on its way out, and that a th350 turbo is the way I should go. Basically now after they readjusted the TV cable the car will shift weird. For example it will go up to 4000 rps and then back down to 3200 rpms to shift. The car feels slow now, and I don’t know what to do. Should I fix the trany, or should I get the th350 and rebuild it b4 I put it in the car, and if I do that will it work with my b&M meagashifter? What mods should I do to the new tranny? Idk wut do u guy think?
Old May 8, 2006 | 06:37 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The turbo 350 has a less steep (higher ratio) first gear. It also has no overdrive. If you feel that the 350 is better for your needs, you should swap it. If you prefer the 3.06 first gear ratio and like the overdrive, you should have a pro trans shop rebuild your 700r4.
Old May 8, 2006 | 07:23 PM
burn0ut305's Avatar
Car: z28
whats the average cost to have a tranny rebuilt? My car is geting to the point where it is only used for shows and at the drag strip tho's are my so called neededs.
Old May 8, 2006 | 08:09 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
In my part of the country, a 700r4 runs about $1000 for a stock(quality) rebuild with a new stock remanufactured converter. This assumes you carry in the trans and do the removal and install yourself. You can spend more or less.
Old May 8, 2006 | 08:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Haha, the mechanic bit is hilarious!
Your tranny doesnt care what speed your doing or what gears are in the back, all it knows is 'o look were goin WOT, spinning up to 5000RPM, time to grab another gear!'
So is your motor a 305 or 350? I see 305 in the post and 350 in your specs...
Either way it seems you have a pretty mild motor so you dont need to go hog wild on a tranny build. but you dont want to just throw in a stock tranny either if you plan on going to the strip!
Old May 8, 2006 | 09:49 PM
blk89 5.7liter's Avatar
Car: 1989 iroc z
Engine: 5.7/350 bored/stroked to 396
Transmission: 700r4 edge 2400 stall
Axle/Gears: 9 bolt 3.27 posi
Originally Posted by Burn0ut350
Well first off it wasn’t my mechanic, It was actually one of the college professors at my college that teaches automotive classes, so I figure that gives him some credibility, and he use to be very big into drag racing.
So this idiot that told you that is a automotive technology professor? I feel sorry for the students he is teaching. This idiot obviously does`nt know his *ss from a hole in the ground. I have known alot of these higher education types that thought just because they went on to college they knew it all when in reality they guy with hands on exp. knew volumes more on the subject. This professor sounds like a first class idiot.
Old May 9, 2006 | 09:11 AM
burn0ut305's Avatar
Car: z28
Well when I bought the car I was told it was a 350, but later found out how to read the block number, and found out its only a 305. If I’m going to rebuild the tranny I’m going to do it right and put the best tranny in that I wont ever have to change, and will be solid as a rock 4 at lest my life time.
Old May 9, 2006 | 11:37 AM
Shagwell's Avatar
...if it's only show and race, go T350 manual valve body and re-gear the rear. If you want to cruise or street much, freshen the 700 and go on.
...and if this auto professor was very into drag racing(with an auto trans) then he should have been running a manual valvebody car that is in what ever gear you put it in, when ever you put it there. - one way or the other, rear-gearing doesn't effect whether or not the trans can shift.
Old May 9, 2006 | 02:10 PM
burn0ut305's Avatar
Car: z28
so where is a good place to start looking for a 350 tranny?
Old May 9, 2006 | 02:48 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
good places to start.. um. classifieds mostly.. I have a stock TH-350 out of an 80 camaro that is just collecting dust. suppose i will sell it one day lol. Another thing about that auto professor.. if you have a 2.78 gears then it is turning 2.78 times for every rotation of the driveshaft if i remember. if you go to like a 3.73 or 4.11 then they are actually spinning faster (IE the gear number is the first part of a ratio so 2.73 = 2.73:1 and the 4.11:1 and so on. Also. Just curious.. are you running a stock quadra jet carb on there? (i ask that alot when it comes to the 700r4)
Old May 10, 2006 | 04:16 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
problem : worn 3-4 clutch pack.
Old May 11, 2006 | 02:06 PM
burn0ut305's Avatar
Car: z28
And i can fix that HOW????
and yes it just the stock carb...
Old May 11, 2006 | 05:59 PM
you fix a worn 3-4 clutch by rebuilding the thing.. I mean since you have the thing appart you might as well replace all of the clutches and such and beef them up a little bit. and replace the servo, TV valve. and the other assorted improvements lol. I do not know offhand what all tools are required to do it at the moment.. but if you are good with diagrams it is not super hard to do.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
