How and what to do to modify Rear Disk Backing Plate?
Old May 10, 2006 | 09:08 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a Moser 9" and need to modify rear disk brake backing plate, So that I may retain the OEM rear brake assymbly. What and how exactly do I do this? The OEM Setup has the backing plate mounted on the axel tube. The 9" tube is way bigger than the 10 bolt it's mounted on. The tube ends are completely different. Anybody with step by step instructions would br greatly appreciated.
Old May 10, 2006 | 09:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What flanges did you order the rear with? If you got the 12 bolt flanges, the 10 bolt backing plates should bolt right on.
Old May 10, 2006 | 10:34 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
I assume they are the big ford ends. They loook night and day different.
Old May 10, 2006 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What bolt pattern are the axles? You could always use Ford brakes, too.
Old May 11, 2006 | 08:26 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Ford brakes are not an option. I have a complete BAER rear kit 2 piston caliper, 12" rotor, rev slotted, cross drilled, zinc washed, YADA YADA YADA!! Absolutely have to make the stock configuration work!
Old May 13, 2006 | 09:41 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Moser must not ship instructions with their rears anymore.
See this post....https://www.thirdgen.org/forums/tran...-9-w-disc.html
Good luck!
Old May 14, 2006 | 09:57 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
IROCZZ3 - They should make your diagram a Sticky. That would help a ton of people. Thanks so very much.
Old May 14, 2006 | 05:20 PM
IROCZZ3's Avatar
Car: 87 Buick GN
No problem glad I could help.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
