need help with choosing complete rear end
Old May 18, 2006 | 12:27 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i found out today that theres a problem with the posi unit in my 10 bolt. about 4 months ago i paid a shop to swap in some precision 3.73's after i fragged my richmond 4.10's. instead of continually dropping money into the rear, im just going to buy a complete rear and install it myself.
from what i've been reading, it seems like strange 12 bolts are the way to go. i'm not dead set on any company, or a certain axle, but i've read enough bad things about moser i want to avoid them. my engine doesnt make huge power, i'd estimate 340 hp to the wheels, i would like the rear to be able to hold up to possible 11 second normally aspirated runs. right now it does high 12's and 11s on nitrous, but its also my daily driver, so reliability is a must.
how difficult of an undertaking is there? i'm mechanically experienced, and i have a gm service manual but ive never done this, and done really know any experience mechanics that could help me.
is there no possible way to use my 10 bolt brakes with a 9 inch or 12 bolt? anything else i ought to know before i dive headfirst into this with my daily driver?
Old May 18, 2006 | 12:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you get a rear with the bracketry to fit a thirdgen, it's a direct swap, just like putting in a factory rear. You should be able to order it with axle flanges to mount your factory brakes, too.
Old May 18, 2006 | 06:24 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i was wondering on what rear is real good alos....ford 9...how much...
Old May 20, 2006 | 11:51 AM
1meanGTA's Avatar
could use some help here guys. is this something i can do in my garage? am i lookin in the right direction with the strange 12 bolt? i would guess my car will never have more than 500 or 550 rwhp, but i want it to hold up to that much.
Old May 20, 2006 | 02:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could do it in your garage, yes. Lots of people here have swapped rear ends in their garage/driveway/whatever.
Old May 20, 2006 | 05:30 PM
1meanGTA's Avatar
i know it can be done is a garage, i guess my question should have been, is this something only a trained professional should do, or can i do it myself without professional assistance other than a gm service manual.
Old May 20, 2006 | 07:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not that difficult really. Disconnect the brake lines, disconnect the suspension components, and the rear falls out of the car.
Old May 20, 2006 | 09:33 PM
'86 350's Avatar
Car: '86 Camaro SC
Not hard at all. It's been a pain in the *** for me to get to my e-brake lines because of the tunnel brace I'm running, but if your not running one then swapping the rear should be easy as pie. I'm in the middle of doing mine right now and I've had no problems. I've just been using basic hand tools, a creeper and a nice big can of PB Blaster.
Old May 20, 2006 | 10:19 PM
1meanGTA's Avatar
i've found aerokroil to work much better than pb blaster.
are you using a jack adaptor for the rear, or just benchpressing it, or what?
Old May 21, 2006 | 12:19 AM
1meanGTA's Avatar
should i be looking at 31 or 35 spline axles, or is there much of a difference? i dont mind spending an extra hundred bucks or two for a sturdier rear, but i dont want to have to worry about it.
Old May 21, 2006 | 01:23 PM
'86 350's Avatar
Car: '86 Camaro SC
Huh, I'll have to try that stuff. I have the jack under the pumpkin of the differential and then I usually get a friend and myself to pull it out from under the car and hold it steady.
Old May 22, 2006 | 05:38 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
yo man taking the rear out isnt a big deal at all. ive done it by myself liek 3 or 4 times. 1st tiem it took me liek 2 hrs now it takes me liek 30-45 mins. just watch out when u lower the rear cuz the springs will shoot at u if u lower it to fast
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
