borg warner
Old May 18, 2006 | 10:07 PM
joel_157's Avatar
Car: 85 IROC
Engine: 305 H.O. L69
Transmission: borg warner 5 spd
borg warner
ok, my borg warner got all messed up, needed new input and output shaft. so istead i just got another tranny. i assumed it would be another V8 bcuz it was another borg warner( didnt know they made them for V6's). and im having trouble with the throw out bearing. my guy said there is 3 sizes, and i need the middle one. is this true? did BW make transmissio for V6 cars?
Old May 19, 2006 | 07:00 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i assume you are talking about the t-5 non-world class and t-5 world class 5 speeds. yes, they made them for v-8 camaros, v-6 camaros, v-8 mustangs, v-6 mustangs, 2wd s-10s and 4wd s-10s.
Old May 21, 2006 | 05:40 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
V6 gearboxes have a 16 spline input shaft and it is a smaller diameter than the 26 spline V8 input shaft. The sleeve the throwout (release) bearing rides on should be the same diameter, I've never heard of using a different bearing for a v6 box. I know I've never used a different one...
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Vojtush31
Oct 11, 2015 01:07 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
scottmoyer
Sep 7, 2015 07:06 PM
