installed posi, it works, but i get "wheel hop".....
Old May 25, 2006 | 09:38 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
So i recently installed a posi unit and new axles, everything went in fine, it works like it should, except i now get "wheel hop" off the line when i go to burn out the tires. both tires spin like they should, but one of them will bounce like crazy causing a violent vibration in the back end. i heard its pretty common in thirdgens, any idea how to stop it so i can do a smooth sweet burnout?
-drew
Old May 25, 2006 | 10:11 PM
EvilCartman's Avatar
Car: '82 Z28
One thing that might help out is to replace your old worn out suspension bushings.
Old May 26, 2006 | 05:58 AM
ede's Avatar
ede
air bags help as will an adjustable torque arm
Old May 26, 2006 | 06:34 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I had the same problem in my 91 formula when I originally got it with the 305 TPI motor.
I switched to aftermarket LCAs and had serious hop. Air bags in the rear springs will cure this. When you install them, make sure you run a separate line to each bag that way you can control the pressure individually.
Easy and cheap fix.
Old May 26, 2006 | 10:02 AM
Engine: Chevy 350ci
i'm on a limited budget, so how much would a set of rear air bags go for?
Old May 26, 2006 | 12:18 PM
Shagwell's Avatar
Car: projects.......
do new bushings/shocks before air-bags. These cars didn't hop factory boys. It comes with age. 99% of the time, thats what's wrong.
Old May 26, 2006 | 10:54 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Actually, most of the tire hop problems in these cars come after you install new bushings and what not. The old bushing and shocks don't help though.
Airbags will set you back about 80 bucks for both sides.
Old May 26, 2006 | 11:10 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I'm sure there's probably alot of guys out there that know more about this than I do but I think I'd go with a set of QA-1 shocks (after bushing renew). You have the choice of deflating the bags for the ride home or, this way, turning a shock valve **** to ride home normally. With the additional suspension control of the shock (they should let the rear settle a little on the top end), I think you'll be happier but a little deeper in the money hole.
Old May 27, 2006 | 08:15 AM
Engine: Chevy 350ci
any recommendation as to where i should order them from, and what kind? (for the airbags)
Old May 29, 2006 | 09:15 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
They are made by AIRLIFT. Best place would be summit or jegs.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
