flexibile oil cooler lines
Old May 30, 2006 | 05:43 AM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i broke one of my oil cooler lines sat. pulling the engine out of my car and i was wondering does any have flexable oil cooler lines. also if i cant find a flexable line where could i found a stock replacement line.
Old May 30, 2006 | 11:37 AM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
anyone?
Old May 30, 2006 | 12:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Not sure about any retail ones...
But i made all of my tranny cooler lines and got rid of the crummy tubing.
Since we are an Aeroquip distributor that was my choice of hose and fittings!
Old May 30, 2006 | 12:35 PM
Shagwell's Avatar
Car: projects.......
you could easily either build a replacement rubber line, or if you just hurt the tub itself, not the end-fitting, you could just cut it off clean on either side and clamp a piece of oil-resistant hose over it. It's not high pressure, so it doesn't take much.
- (I work at a Parker Store, so )
Old May 30, 2006 | 01:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The factory oil cooler lines carry coolant, not oil. Just get some heater hose.
Old May 30, 2006 | 03:46 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I assume he was talking trans oil cooler...
But who knows
Old May 30, 2006 | 05:09 PM
Shagwell's Avatar
now that I noticed he said oil cooler lines not trans cooler, yes, just get some heater hose & some hose barbs(if needed).
Old May 30, 2006 | 11:04 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
sorry i hadnt check the post recently but i meant transmission cooler lines sorry for the mix up.
Old May 31, 2006 | 12:20 PM
Shagwell's Avatar
...i meant transmission cooler lines...
then just do as I said in my first post. Trans lines are low pressure.
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
