9 bolt question???
Old Jun 9, 2006 | 02:28 AM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
9 bolt question???
ok i got a question. i found a 9 bolt on a camaro in the junkyard and brought it home. however this mechanic by the house said i would need all kinds of modifications, since he said that 9 bolts are only for fords! is this so? because i have seen many camaros/firebirds with 9 bolts! was this an option or are they really suppose to be for fords and people just make them work on third gens?
Old Jun 9, 2006 | 03:48 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
no ur mechanic is talking about the ford 9inch rear. the 9bolt u have will bolt right in.
Old Jun 9, 2006 | 05:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 2badcams
this mechanic by the house said that 9 bolts are only for fords!
Wrong.
JamesC
Old Jun 9, 2006 | 09:32 AM
Frank89IROC's Avatar
My 89 IROC came stock with a 9 bolt posi-rear. I believe they were made in Australia for GM for about 3 years in the late 80's. The 9 bolts were made stronger than the 10 bolts, but because they were made for only a few years it's difficult to find aftermarket or replacement parts.
Old Jun 9, 2006 | 12:48 PM
Shagwell's Avatar
Car: projects.......
a 9" is Ford, but can/has been put into almost anything.
a 9-bolt is an Australian built 3rd gen GM rear.
Old Jun 9, 2006 | 04:55 PM
2badcams's Avatar
thanks guys! that was very helpful!
Old Jun 9, 2006 | 10:13 PM
kurtrangen's Avatar
Think it over, if you have the ten bolt now. The conversion will cost lamost as much as a aftermarket locker for the 10 bolt. Parts are easier to get for the ten bolt.
Old Jun 11, 2006 | 07:09 PM
Shagwell's Avatar
conversion costs? A 9-bolt is bolt in and is stronger than a 10-bolt.
Old Jun 15, 2006 | 06:13 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Just keep in mind that the 9-bolt is difficult to find parts for. Don't get me wrong, you can get them, but they are definately tougher to locate. There are also special procedures that need to be followed when working on them that seperate them from the typical 10-bolt.
What needs to be converted? I believe you simply remove the 10-bolt, and install the 9-bolt. You might change the end-links, but that's about it, or so I think.
Last edited by 87IROCZ350TPI; Jun 15, 2006 at 06:15 PM. Reason: Automerged Doublepost
Old Jun 18, 2006 | 07:47 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
9 bolts aren't THAT much stronger. a 10 bolt rear end has a 7.5" ring gear, the 9 bolt is a 7.75" iirc, along with one other minor thing.
imo either put some gears in the 10 bolt or save some cash for something tough (ford 9 inch or moser 12 bolt).
Old Jun 18, 2006 | 07:56 PM
Car: 87 IROC
Engine: 5.7 TPI
Are you sure that a 9-bolt isn't much stronger? I don't know much about these rears, but I've heard a lot of talk that they have a large strength advantage over the 10-bolt. Don't take this as a challenge, I'm just inquiring. I have a 9-bolt and being that parts are a bitch too find, I may consider swapping out to a 10. I just haven't because of what I've heard regarding their increased strength.
Old Jun 20, 2006 | 01:12 PM
Shagwell's Avatar
strength isn't just in a gear diameter, it has a lot to do with the housing itself. The less flex there is in the housing, the less the gear can deflect. The 9-bolt case is cast better. After running both, I would say the axles are better material also(plus they're slightly larger).
For a moderate performance street car, a good 9-bolt will hold up a long time. It takes a girdle and upgraded axles to make a 7.5 10-bolt take it very long.
Old Jun 23, 2006 | 07:14 PM
glperkins's Avatar
Car: 1948 CHEVY PANEL TRUCK
Engine: 305tpi
unless you are running big #s horsepower what differents does it make from a 9 or 10 bolt they are both for the street not made to race
Old Jun 23, 2006 | 07:26 PM
Shagwell's Avatar
? - with a 4001lb car running 11.7X's with a 1.66 60ft on 17" dr's, I would have to say I'm putting down some big hp #'s. The car was a daily driver(before the tear down) and is running a built 7.5 10-bolt. There are a few members on here running in the 10's on a 7.5 10-bolt, and a several running mid 11's on a 9-bolt. The 10-bolt guys are modded, and the 9-bolt guys basically have none they can do. - If you're looking for much more than that, you're not looking at anything factory......
Old Jun 24, 2006 | 10:16 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
9 Bolts can take alot more abuse than a 10 bolt. You need to get rid of your mechanic if he doesn't know the difference between a 9bolt and 9inch.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
