which flywheel/clutch combo to use
Old Jun 10, 2006 | 12:56 PM
theredline's Avatar
Car: 86 iroc
Engine: the 305 tpi that could
Transmission: soon to be WC 5spd
Hey I just bought almost all the parts I need (just need flywheel, clutch, and bellhousing) for a t-5 swap into my 86 auto. Its a 305tpi and I was wondering does the number of the teeth matter? At summitracing.com, I can either pick 168 or 153 th flywheel. What is the correct size flywheel my engine?
Also, I also don't know what size clutch to use? 10.4, 11
I'm alright at driving stick, it'll come with time but can anyone recommend a decent clutch, better than stock?
Anyone have bellhousing/flywheel, let me know thanks.
Old Jun 10, 2006 | 02:13 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
you have to get the 153 tooth flywheel. the 168 tooth doesn't fit inside the bell housing, also the starter is different for each. I bought my flywheel at Advance auto for like $60something
I think its the 10.4" clutch
Ram and Centerforce are popular aftermarket clutch brands. I've heard good things about the Centerforce dual friction clutch.
does your engine have a 1 piece rear main seal? I have a flywheel for that
Old Jun 10, 2006 | 04:04 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
the 168 tooth is for motors with a 400 crank.. i have one for my stroker and i had to get a bellhousing.. simply doesnt fit in the stock bellhousing.. and i would recommend the centerforce dual friction clutch.. i have one on my TA and it has never slipped.. even on slicks.. also has a lighter clutch pedal feel..
Old Jun 10, 2006 | 05:27 PM
theredline's Avatar
Car: 86 iroc
Yes I just looked up on another site, that its a one piece rear main seal. How much would you let that flywheel go for. Obviously less than $60 (brand new)
Old Jun 11, 2006 | 10:43 AM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
Axle/Gears: 9 bolt, 327 gears
i have flywheels, a bellhousing, clutch, everything you could need. let me know if you still need stuff.
Old Jun 11, 2006 | 11:11 AM
theredline's Avatar
Car: 86 iroc
Do you have the correct flywheel (153 teeth)? Can you send pics of the wheel,bell and clutch(10.4in)?
Old Jun 11, 2006 | 11:29 AM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
i can send you some tommorrow. leave me your email.
Old Jun 11, 2006 | 06:52 PM
Shagwell's Avatar
Car: projects.......
not true. Either size flywheel is available for external or internal balance motors. I run a 168 in my car with an 11" clutch. My scatter-shield doesn't care either.
Old Jun 19, 2006 | 02:52 AM
Pat Hall's Avatar
He's right. I'm also running an 11" clutch and a hays 168 tooth flywheel behind my internally balanced 355 in my 69 camaro. I did have to get the starter for a 396 engine to work with the larger flywheel and different bellhousing when I upgraded from a 10.5" clutch to the 11". The 396 starter had a smaller nosecone than the 350 starter, just like the T5 starter's nosecone is smaller than the 700r4 starter's nosecone.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
