Eaton Posi Unit
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Eaton Posi Unit
Was wondering if buying a Eaton posi unit was worth it money and power wise? I don't have money for a 9inch or 12 bolt and could get the Eaton posi for around $120. What else would I have to do to make it work?
Eaton "posi" for around $120? I'm guessing used..... You sure you're not looking at a powertrack type unit? - Either way, you're still talking stock, easily breakable axles and other rear diff components.....
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
for $120 it's a steal. i bought mine for $250 used.
and the powertrax units are $399 new...and aren't worth a dang.
As long as it's not a "Gov-Lock"....
I'd pay $120 to get one of those out of my rear end (let alone my car's) if I had one.
That particular unit is stock in S trucks, especially 4WD ones. It acts like an open, until the difference in RPM between the 2 axles exceeds some value like 100 RPM; at which point it tries to lock up. In other words, you get no posi action whatsoever until tire spin has already occurred. Then it tries to lock up with a bang, and that makes the vehicle unstable; and tends to make parts fly out through the cover. One guy on here found pieces of his in his gas tank... after all the fuel drained out the holes the shrapnel made on its way out of the rear and into the tank.
Look in the little "window" in the carrier. If you see 2 little weights on little bitty shafts, RUN AWAY!!! It's a Grenade-Lock. They tend to live up to that affectionate nickname.
Car: 1992 RS Black
Axle/Gears: 4.10
Well the auction is now going up to $200 or more so I may just rebearing and seal my rear and put a new gear ratio in it for now.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I loved my Eaton till it broke last week. you can get them for $399 new from Ring and pinions, posi units for Chevrolet, Camaro and Ford or up to $500 from other vendors.
just be aware that they are a wearable item and possibly factor in the rebuild cost while buying a used one.
Car: 1992 RS Black
Axle/Gears: 4.10
After review what you guys said that the auction went up and i missed it. I think im just going to rebuild my rear and put a high ratio ring and pinion and see how long it last. I'll save for a 9inch later.
