How do I tell a third from a fourth gen rear?
Old Jun 22, 2006 | 08:56 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I am looking at a rear this weekend for a friend its out of the car and I ned to know if it is a third or fourth gen rear...since they pretty much bolt in I dont know how to tell them apart
If you do it by length I need some measurements to go by...Thanks
Old Jun 23, 2006 | 12:12 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I do believe the length is 65.5". There would also be the ABS sensor ring inside the the diff and then on the axles for the ASR option, if it was equipped.
Old Jun 23, 2006 | 12:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
to tell at a glance i look at the top of the pumpkin... if it has a boss for the ABS sensor cast into it, its a 4thgen rear... if it doesnt, its a thirdgen rear..
the boss may be drilled for the sensor, or it may not, depending on if the car has 3 channel or 4 channel ABS.... but the boss is still cast in there.
Old Jun 23, 2006 | 06:57 PM
dwillis's Avatar
Axle/Gears: 3:08
ABS Right!I didn't even think about that thanks guys..Dave
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
