Adjusting Throttle valve cable
Old Jun 28, 2006 | 07:12 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
How do you adjust the throttle valve cable on a 700R4? I don't understand what the book says.
Old Jun 28, 2006 | 08:14 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok I think I got it all I had to do was push that button, push the thing back all the way then let go of the button then push throttle all the way open and it should click into place right? Please let me know if I did that right.
Old Jun 28, 2006 | 08:43 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Old Jun 29, 2006 | 11:26 AM
CamaroX84's Avatar
Yeah you did it correctly. Just make sure that when the throttle is all the way open, the TV cable is tight and you can't pull any of it out of the trans.
Old Jun 29, 2006 | 06:46 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok thank you.
Old Jul 1, 2006 | 03:19 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I recently had to replace my TV cable.
Got it in, and I adjusted the thing all the was back (to the mount bracket) and this car will not go into 2nd untill darn close to 40 MPH!
Looking at it while the throttle is closed, there is a good 1/2"-5/8" of cable ahead of the kick down clip.
On my old one I had it just like this one is and it shifted at around 20.
Old Jul 1, 2006 | 03:39 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
did you push the throttle open by hand until it stops against the stop not just because it won't move you have to make sure the throttle is al the way to the stop you should hear the adjuster ratchet into place.
Old Jul 1, 2006 | 03:48 PM
V6sucker's Avatar
Engine: blown up
yes by hand (opening the throttle).
I pulled the cable all the way out by hand and never heard a "click"
I could feel the tension on it from the TV valve though.
Old Jul 1, 2006 | 04:18 PM
V6sucker's Avatar
Engine: blown up
got it sorted thanks
Old Jul 2, 2006 | 01:41 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Could you tell me what you found so I can remember that in case I have the same problem?
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
dhonda200
Aug 11, 2015 11:50 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
