82 z28 th350 to 700r4?
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i plan on changing my th350 over to a 700r4 soon i was wondering is there enough room to make crossmember for true duals and all i really need is to lengthen the 700r4 member to make it work correct and get a 700r4 drive shaft? any help would be great and if anyone has pics of someone that has a 700r4 in an 82 taht would be awesome thanks
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It doesnt really matter what tranny or crossmember is in there, true duals dont tuck in very well unless their run in the stock location...
Car: 82 z28
Transmission: TH350
yea i know they dont but it will be better than my current setup and i have longtube headers so the stock location is out of the question
I've said it before, and I'll say it again, "true duals aren't worth the work."
- Even with LT's, run a custom y-pipe(or Mufflex) and a good 3" or better cat-back. There is zero power difference from single to duals, so why go through all the work to have less gound clearance and a different sound?
- From 350 to 700 the ds may work. The 700 is slightly longer, but probably not enough so that the factory yoke travel would be used up. - The crossmember may work, but if not a j/y piece should be really cheap.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Nothing sounds as good as a set of duals though...
Sure a good y-pipe setup sounds good but i dont think you will ever get the sound you can with full duals!
Car: 82 z28
Transmission: TH350
ok thanks for all the info but i dont care if its not worth the work in your opinion its what im doing thanks again
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Third gens never came with a TH350. The early third gens with an A3 have a 200c in them not a TH350.
Car: 82 z28
Transmission: TH350
yea originally it came with a 200c but the previous owner swaped the th350 in and ive decided i really want overdrive
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
