speedometer
Old Jul 8, 2006 | 10:27 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
speedometer
i have bigger tires and will be going with lower gears.i have a 88 iroc. i am going to have to get the kit that uses vacuum instead of electric.so do i go with a programable speedo?
Old Jul 8, 2006 | 10:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure of what you're asking. An 88 IROC would have a cable-driven speedo. To make it read correctly, you may have to swap out the drive and/or driven gears. Search for a calculator to establish your needs.
JamesC
Old Jul 8, 2006 | 10:59 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
speedo
i forgot to mention i am putting in a carb and doing away with the computer.i was looking at autometer and they say you just have to program it every time you change gears or tires.is this correct?
Old Jul 8, 2006 | 11:09 AM
JamesC's Avatar
My 85 IROC (mechanical speedo like yours) has a transplanted, carbed 350 and the computer has been eliminated. These things have nothing to do with the stock speedo. Sorry, I have no experience with Autometer, but I suspect this guage won't work with a mechancial set-up such as yours.
JamesC
Old Jul 8, 2006 | 11:36 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
speedo
thanks jamesc i guess thats for non cable trans
Old Jul 8, 2006 | 12:01 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
yeah as stated you have to change the drive and driven gears in the tailhousing of the transmission to get your speedo right again. here is the one i used. Speedo calculator
Old Jul 8, 2006 | 12:41 PM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
thanks,i was afraid of that,the so called mechenics in this area do not have a clue on how to do it,i have been to every one
Old Jul 8, 2006 | 01:34 PM
JamesC's Avatar
https://www.thirdgen.org/speedogear
JamesC
Old Jul 8, 2006 | 02:00 PM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
speedogears
Originally Posted by JamesC
thanks,so if i get my ratios right i have to keep buying the same size tires for it to be accuarate.i have 29 inch tires with 273s.will be putting in 342s maybe with the tall tires and lower gears it won't be too far off.stock tires were215-65-15 i have 255-70-15
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
