Borg warner 7 5/8
Old Jul 9, 2006 | 06:40 PM
383TA86's Avatar
Car: 86 TA
Engine: 2.8 HO
Axle/Gears: yepper
Borg warner 7 5/8
will anyother carrier fit or do i have to find some one that makes a gut pack and ring and pinion?
Old Jul 9, 2006 | 08:26 PM
Are you asking about a B-W rear, or a 7-5/8"?
They're not the same thing.
How many bolts hold your cover on?
Old Jul 9, 2006 | 08:57 PM
383TA86's Avatar
Car: 86 TA
Engine: 2.8 HO
Axle/Gears: yepper
Ok lets do this again.
Fact... 9 bolts on the cover
Fact... Made by Borg Warner
Fact.. The axles bolt in like a Ford 9 inch
Fact... Has rear disk brakes with stupid *** e brake on it
Q... Who makes part for them like carrier,ring and pinion?
Old Jul 10, 2006 | 06:15 AM
OK, it's a B-W then, and NOT a 7-5/8". Its ring gear is actually 7¾", and is listed as such in the parts books. 7-5/8" is a 10-bolt size.
Borg-Warner makes carriers for it. I don't know of anyone else. I don't think new ones are available in the US. There are sources in Australia, where they're made; but finding them in the US is not easy, and not cheap when the do appear.
R&P is available in a few ratios, from a number of sources. Drivetrain Specialists has a few, and I believe Randy's might also have them. A guy used to be on this board alot a long time ago, had a site called 9bolt.com and later diffsolutions.com; but I think he's got out of the business, due to inadequate real interest (lots of talk, no actual buyers), even though the URLs may still work.
Old Jul 10, 2006 | 05:33 PM
383TA86's Avatar
Car: 86 TA
Engine: 2.8 HO
Axle/Gears: yepper
thanks for the help. Now i am going to go find a diff out of a 4th gen and put that in. At least then I will have a 10 bolt so i can buy parts for it.
Old Jul 11, 2006 | 02:39 PM
Shagwell's Avatar
Car: projects.......
...At least then I will have a 10 bolt so i can buy parts for it.
....which will be needed if you start putting down good power. - I did the same thing, but only because a solidly built 10-bolt got "handed" to me.
Old Jul 11, 2006 | 02:50 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You are thinking about the complete rear axle assembly and not just the internal 4th gen parts???
Old Jul 11, 2006 | 05:39 PM
383TA86's Avatar
Car: 86 TA
Engine: 2.8 HO
Axle/Gears: yepper
come on man you have to ask me that. lol
Old Jul 11, 2006 | 09:09 PM
DJP87Z28's Avatar
Check your first thread and it didn't make like you knew a lot. So lol to on your project.
Old Jul 12, 2006 | 01:53 PM
Shagwell's Avatar
an 86 10-bolt would be 26 spline axles, which means nothing out of a 4th gen rear would work, unless you were gonna use the later-model carrier and buy axles.
- anyhow, he said he has a 9-bolt, which means complete rear swap. Yes more parts are readily available for a 10-bolt, but you're dancing on egg-shells if you start putting much power to the ground.
- If you can't afford to do it right the first time, can you afford to do it again?
...start searching for a 9" or a 12-bolt, otherwise just stick with the 9-bolt.
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Vojtush31
Oct 11, 2015 01:07 PM
roysatikas
Sep 22, 2015 08:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
