200c transmissions
Old Jul 11, 2006 | 05:18 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
200c transmissions
Well first of my friend has a 1983 camaro 2.8l with the 200c. well i not sure how good these tranys are but he thinks it may be slipping. does anyone know how good these trannies are?
Old Jul 11, 2006 | 06:05 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
They are not very strong.
Old Jul 11, 2006 | 06:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
must be pretty bad to slip behind a 2.8!
Old Jul 14, 2006 | 09:18 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I read the 200c were not durable, unlike the 200 4R which holds up in ordinary applications. You will find info on this if you do a search.
Old Jul 14, 2006 | 01:37 PM
Shagwell's Avatar
Car: projects.......
the 200c is exceptionally weak. - Tell you're friend to start looking for a t350 in a junkyard.
ordinary? low 10 sec GN's aren't exactly what I'd call ordinary....
Old Jul 14, 2006 | 03:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
The 200 4r is basically the same thing as a 700r4 but has closer ratio gears, it was designed for use in light cars.
Now if its actually true that its pretty much a 700r4 i wouldnt trust it too much in these big boats!
Old Jul 14, 2006 | 03:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 200-4R and the 700R4 have nothing in common. They're entirely different designs.
Old Jul 17, 2006 | 10:58 AM
Nope, me neither!
I haven't heard of anyone building a 200c (it fails behind ordinary engines), but a 200-4R is rated to 330 ft.lbs. stock, and reputedly can be built to deal with a supercharged nitrous-injected small-block. It's a nice little tranny with even gear spacing and a high o.d. good for both higway & strip. Being small should make for low h.p. loss, I guess?
My memory sometimes fail me, but doesn't some repair books deal with the 200 and the 700 in the same book, many parts being the same?
Old Jul 17, 2006 | 12:31 PM
Shagwell's Avatar
C.R.S. - can't remember sh*t
- nope, they're completely different.
Old Jul 24, 2006 | 12:09 AM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
That would be me LOL but every time I try to go up a hill it just does nothing have to flore it then when I get to the top were its flat it starts acting funny almost like its sliping but after you drive it a lil ways it stops these trans are weak but there better then nothing I think LOL
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
3rdgenparts
Aug 6, 2015 09:03 AM
82CamaroZ28
Jul 24, 2003 10:07 AM
3rdgenparts
Jun 16, 2003 07:27 PM
lukerene
Jun 3, 2003 04:02 AM
