Auto to T5 Ran into a Snag
Old Jul 20, 2006 | 04:00 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Ok well heres the scoop, I got the auto trans out, along with all the pedal assembly, I got the new pedal assembly in, the slave, new flywheel, clutch disc, pressureplate. and the trans is in. new B&M short shifter. But I cant shift gears, with the clutch pedal pressd in or out. I can move the shifter around a little bit, but I can only feel it attempting so to speak, to go into 1st and 3rd. Any thoughts? I really need this done asap Hate it when things go wrong
Old Jul 20, 2006 | 04:03 PM
Sounds like the little **** on the bottom end of the shifter missed the little hole it's supposed to plug into.
Old Jul 20, 2006 | 04:11 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
I'll check that, aside from that, any other ideas ?
Old Jul 20, 2006 | 05:35 PM
t-rex_camaro's Avatar
Car: 1991 camaro rs
Transmission: auto
Axle/Gears: 2 axles and a set of gears
how much is realy needed for a swap to a 5 speed. g/w i am planing on doing it tomy 1991 camaro... sory to get of topic but gust wandring. thanks
Old Jul 20, 2006 | 06:39 PM
Check that first, then come back fishing for more ideas.
If the trans hasn't been into, then that's the ONLY thing that can cause it.
If someone has had their paws in it, then all bets are off. You'll just have to take it back apart and see what they messed up.
Old Jul 21, 2006 | 11:39 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
Goto this link, it'll answer your question
https://www.thirdgen.org/manualswap
Old Jul 21, 2006 | 12:27 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
Double checked the shifter, its in there right. but the damn thing still wont shift at all
Old Jul 21, 2006 | 12:38 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Camarosource.ca - Camaro Message Board :: View topic - **Changing an Automatic into a Standard**
Old Jul 21, 2006 | 01:15 PM
Well then, needs to come back out, and come apart, and figure out what the last person who took it apart and put it back together since it last ran, did wrong.
Old Jul 21, 2006 | 04:20 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
See the weird thing is though, I took this trans out of the donor car myself, and it ran fine in that car... So I'm not sure what the hell is going on.
Old Jul 21, 2006 | 10:05 PM
ChrisColeman's Avatar
Filled the clutch master and bled the system completely out?
Old Jul 22, 2006 | 12:09 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
yes sir i did
Old Aug 29, 2006 | 11:02 PM
smallblock383's Avatar
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
I know you may think this is a rather dumb and somewhat elementery thing to check but...I had a friend do this swap in his 86 camaro and he wanted to do it all by himself. So naturally I got a telephone call saying that he coujln't get the &^%*ing thing to go through the gears. I had preformed this swap a few times and knew what to look for. I went through all mechanics and found he did a good job except he didn't make the hole in the tanny tunnel large enough (used to be a 700R4 car) to flow through the gears. Good Luck and let us all know how you make out...I'm curious
Azrael91966669
25
Jun 20, 2017 04:04 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Linson
Oct 1, 2015 09:50 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Leggman1
Aug 6, 2015 04:15 AM
