transmission help
Old Jul 22, 2006 | 08:27 PM
dojo55's Avatar
transmission help
after hours of searchin i couldnt find anything that related to this question so my apologies if this is a repeat...
im running an 87 trans am gta, my tranny went, and im lookin for a cheap fix... its a 305 tpi... wat transmission goes with that, is it the th700r4?
and if so, do u guys foresee any problems taking the tranny from a gm truck and tossing it my gta?
Old Jul 22, 2006 | 08:31 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Your car should have a 700. If the truck has a 700, it can be used.
Old Jul 22, 2006 | 08:35 PM
dustpusher's Avatar
Car: 88 IROC-Z
It is a 700r.Shouldnt be a problem but you will have to change the tail of tranny.Truck tranny dosent have a place for the torque arm to mount to.
Old Jul 22, 2006 | 08:36 PM
dojo55's Avatar
it does have a 700, but will the mounting places and gear and tail shafts all match?
Old Jul 22, 2006 | 08:38 PM
dustpusher's Avatar
Car: 88 IROC-Z
If you want to keep the torque arm you have to just change the tail .
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If you switch the tailhousing, yes.
Old Jul 22, 2006 | 08:41 PM
dojo55's Avatar
changing the tail expensive? can i pull one off a 700 at a junkyard or should it be rebuilt/bought new.....sorry, i dont kno much about drivetrains
Old Jul 22, 2006 | 08:43 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Take the tailhousing off the f-body trans and install it on the truck trans. No need to buy anything.
Old Jul 22, 2006 | 08:48 PM
dojo55's Avatar
drive shafts should match fine?
Old Jul 22, 2006 | 08:54 PM
dustpusher's Avatar
Car: 88 IROC-Z
Everything should be the same.Just make sure you dont get a tranny from a 4x4 they are different.
Old Jul 22, 2006 | 09:25 PM
dojo55's Avatar
thanks for the help guys anything else i should watch out for, any other opinions?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
