700-R4 Help Please!!!
Old Jul 29, 2006 | 02:14 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello all,
I have a 700-R4 that will not shift. Reverse works, I adjusted the TV Cable, full of ATF, The transmission has been beefed up about 2 years ago. The transmission worked great yesterday, I get up this morning and put in drive and I start moving but it will not shift up. I drop into first and it moves then put into 2nd and it seems to shift but its not a hard shift like I am use to, then I can put it back into first and it drops. I am very confussed about this.. please help any suggestions will be greatly appreciated.
Brad
Old Jul 29, 2006 | 08:36 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
hum, got me on that one, was going to say maybe boost valves but you said reverse works, so it shouldnt be that, if you dont get any one to respond private message 87zjeff, he has helped me out a lot on building my tranny, or shagwell, he might have some ideas
Old Jul 30, 2006 | 06:44 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
If the 1-2 shift is getting weaker/sloppier/slips then your 2-4 band might be going out. It is pretty common, and if the trans was rebuilt to have a hard 1-2 shift it will wear the 2-4 band out quicker.
Old Jul 30, 2006 | 09:20 AM
Vader's Avatar
Will not shift? Does that mean it will enter DRIVE, but remain in 1st, or that there is no DRIVE at all?
Old Jul 30, 2006 | 10:41 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
I can enter Drive but will not up shift to 2nd. Always stays in first. Going to remove the valve body assembly and do a visual inspection.
Old Jul 30, 2006 | 10:53 AM
Car: '94 Z28
Engine: LT1 350
2-4 band. Try flooring it, then letting off so you have enough MPH to get directly into third. If it goes into third, but will not continue into fourth then you know its the 2-4 band forsure.
Old Jul 30, 2006 | 02:33 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Need help to locate where this check ball goes.
Heres the deal, removed valve assembly and the metal plate is attached to tranny and it has two check ball on the inside of the plate, the valve assembly has two check ***** in place, however I did not see this ball fall just say it rolling on floor, its a pretty big ball. Please help so I can find is home and get my tranny back together and to shop, I should have never tried to fix this...
Guess I just need a diagram to show me where all the check ***** go, I can not find a diagram anywhere
Old Jul 30, 2006 | 05:04 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
I found where the check ball went, it was for the TV Cable. However my question is now, when I look up the cable to TV valve mechanism, the part that pushed the check valve is (like a needle) is always pushing the check ball. The springs are good, just doesn’t look right with the part pushing the check ball, I adjusted the TV Cable but it just doesn’t seem right, unless once I add fluid and the check ball will push the spring. Any ideas or comments??
Old Aug 7, 2006 | 02:45 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Band might be worn out. Also inspect servo and governor.
Old Aug 7, 2006 | 06:16 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
sounds like a band to me.
as far as the plastic ball not seating, don't worry about it. i leave it out of every 700 i build. all it is for is to make sure the cable is hooked up properly. if the cable isn't hooked up, the ball seats and doesn't let the tranny upshift. if the ball isn't seating, it isn't your problem.
Old Aug 9, 2006 | 07:00 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
It turns out to be 2/4 band, I really dont understand how it could break while just sitting in my drive way!!.... I drove it home on the HWY for 25 miles, then next day it wouldnt up shift to 2nd. I am so confussed. but poo poo happens. I can rebuild a motor, but a tranny is out of my league!!
Brad
Old Aug 9, 2006 | 07:04 AM
Pro Built Automatics's Avatar
If you lost 2-3-4 all at once, it is most likely the governor gear, stripped or broken. If you were to floor it, the transmission should still shift at WOT to 2nd gear, but as soon as you let off of the throttle, and start slowing down it will go right back to first gear, this is because the governor is not spinning. That happens often, stripped or broken governor gear. The 2nd (other) reason is a "stuck" throttle valve in the WOT position, and or the TV cable has frozen up, most likely the governor gear.
Brendan
Feb 20, 2003 02:14 PM
mystikkal_69
Car Audio
Dec 8, 2001 07:20 PM
FIRECHICKEN
Dec 4, 2001 08:56 PM
ADMZ24
Aftermarket Product Review
Apr 26, 2001 02:40 PM
kidpunkr
Jul 28, 2000 07:52 AM
