82 with LG4 and 200c 2.73 or 3.23
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok i found this thread just now by accident and blyth18md has the identical drivetrain as mine and many others' here 82's do, his got 3.23 ratio
mine got 2.73 garbage
https://www.thirdgen.org/forums/prob...info-main.html
on TGO's spec pages it shows that the LG4 cars in 82 all got the 2.73 axle
and says nothing about any optional ratios
i am confused ?
did someone special order blyth's 82 to be 3.23 specifically, or what ?
very curious to learn here
please elaborate if possible
thanks
i am confused ?
thanks
Engine: 4.3L Z TBI
what was original drivetrain ?
another funny one is the 82 z-28 i just parted it was an LG4 4 speed manual car and it was 3.42
so what the heck is going on
they really must not have thought that mine needed a decent axle ratio, for some odd reason
hum
thanks
hum
thanks
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's original drivetrain. Had an LG4 if that's what you meant.
Engine: 4.3L Z TBI
ok i dont know my car (side-loader) 4 speeds very well but thats the 4 speed right ?
what would also have been in the 82 z28 i just stripped, it was LG4 and 4 speed
thanks
thanks
Car: 1982 Trans-Am
maybe.
Where was reverse, top left, or bottom left?
is the case aluminum, or iron.
If it was top left, and aluminum, you have yourself a highly desireable superT10 trans, hold on to that baby.
If not, just a POS saginaw, dump it in your local pile.
KO1
16
Oct 15, 2015 05:00 PM
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
