700R4 Question
Old Aug 11, 2006 | 10:14 PM
LIGHTS OUT's Avatar
Car: FORD 5.0L LX CONVERTIBLE
Engine: 302 V8
Transmission: T5 5 SPEED
700R4 Question
Car holds gear quite nicely when banging gears through 1-2-3 but when left in D the vehicle tends to shift very early in the rpm band from 1-2 and also from 2-3. The car accelerates quite nicely but the 1-2 shift in D at WOT seems weak (shift takes place @ 2000 rpm) Is this quite normal with this transmission or should it be looked at.
Paul
Old Aug 11, 2006 | 10:26 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
700r4 you can adjust your detank cable to control pressure i had too do it on my comaro it will change your shift points some depends on how you adjust it
Old Aug 11, 2006 | 10:30 PM
LIGHTS OUT's Avatar
Engine: 302 V8
I would be interested to learn what type of shift point people are experiencing with their vehicles @ WOT when the shifter is left in D?
Old Aug 11, 2006 | 10:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The governor springs in the tranny decide when its time to shift (WOT) Messing with the TV cable other then normal adjustment is just asking for damage. Leaving it in D and OD wont make a differance. It wont shift into 4th at WOT.
Old Aug 11, 2006 | 10:40 PM
LIGHTS OUT's Avatar
Engine: 302 V8
There are a few reputable shops here in Toronto, Ontario, Canada that I can have a TV cable inspected and adjusted. Perhaps it would be worth a visit. Car accelerates nicely when manually shifting vehicle but the question remains whether or not the vehicle is shifting to early in the rpm band. I have not had to much experience with automatic vehicles but for example my father's car when left in drive and hammered pulls hard in the rpm band and seems to shift at peak horespower for instance.
Old Aug 28, 2006 | 05:26 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
If i were you, id get a ratchet shifter and a fully manual shift kit. Improves the tranmission life quite a bit, and you decide when to shift, no messing around with spring tensions or TV cables. Will be around $200 with parts and installation. But dont mess around with that TV cable, the shift points are determined with springs like mentioned above.
Old Aug 28, 2006 | 02:09 PM
Shagwell's Avatar
Car: projects.......
if it's a street car a manual vb is not the way to go. - You can check/adjust the TV cable very easily yourself(do a search, it's been covered many times). - Once it's properly adjusted, take it for a spin and see how it shifts. If it still needs the shift points raised, then you need to re-calibrate the governor to tune it to your shift points(rpm). - These kits can be had for around $40 summit/jegs/etc.
- as stated, there is only one proper adjustment for the TV cable, it should not be used to adjust shift points.
...also, most 700r's will shift firmer during manual shifting because the vb ups the line pressure when in 1/2/3 under manual control.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
