Need some schooling on axle rebuilding
Old Aug 14, 2006 | 09:38 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I found out my Posi units was toast to I just removed it to rebuilt. I have a Ratech rebuild kit installation kit and Eaton Truetrac I need to install into my 10 bolt. Maybe it was wishful thinking, but the kit didn't come with any instructions. Is there a recommended book out there that covers rebuilding this axle?
Old Aug 14, 2006 | 10:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I just used my haynes and Helm, not a lot of parts in there.
Just gotta know how to reset the backlash probably, etc.
I highly recommend a solid spacer rather than the crush sleeve (unless ratech gave you the spacer).
Girdle too.
Lemme know if you have any specific problems, I did mine in the fall.
Old Aug 14, 2006 | 11:45 PM
trumps2000's Avatar
Car: 1985 Z28
Thanks Sonix. I'm reading up on your threads, to learn how to do this. Gotta a couple of questions for ya.
The cross shaft doesn't want to come out. How did you coerce this sucker?
Where can I get main cap studs? ARP apparently doesn't sell these and Summit didn't know either.
Are 28 axle splines a significant upgrade? I ordered the 26-spline for my car, not thinking about upgrading the axles, but now that everything will be apart I'm thinking it would be a good idea, though I've spent too much $ on the car thus far.
Thanks for your help.
Old Aug 15, 2006 | 03:39 AM
ede's Avatar
ede
tap the cross shaft with a hammer or punch, you do have the bolt out right? 28 spline axles would be a good up grade. don't think i ever seen studs for the rear caps. there's a chance you could find s head bolt stud to be the correct length or find studs from an industrial source.
Old Aug 15, 2006 | 09:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
TA performance has the cap studs. They're cheaper if you buy their girdle too.
Yea, I beat the crap out of my cross pin, had to rotate it so that when I hammered it inwards, I could still rotate it and grab part of it. Do it so you're driving the side with the hole in it, outwards. The hole being where the 5/16" headed bolt was. After that's out a ways you can pry in that hole, to slide it out. It was a big PITA. Removing the carrier was even harder.
I'd use a new crossshaft, since your's may be beaten up once you get it out. A stock one, or GM one is about $14. Don't ask what I paid for a zytanium one, I don't recommend that choice.
Old Aug 15, 2006 | 12:15 PM
trumps2000's Avatar
Car: 1985 Z28
Sonix, Do you have a p/n for the main cap studs? TA tells me they only offer them for the Buicks? wierd ..
Old Aug 15, 2006 | 01:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Rear End Girdles
TA1809 is the cap
TA1815 is the bolts, $20 if you buy the cap, $25 if not IIRC.
Old Aug 15, 2006 | 08:03 PM
trumps2000's Avatar
Car: 1985 Z28
Thanks for the p/n, ordered them up and the new set of axles.
Old Aug 15, 2006 | 11:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Which brand of axles?
If you still have the choice I'd recommend superior brand. They are hardened after machining giving them much more strength. Virtually the same price at $211 for the pair.
Old Aug 16, 2006 | 07:34 AM
trumps2000's Avatar
Car: 1985 Z28
Yup, the superiors. I have to send back the Eaton since its only 26 slpine,but not a big deal.
NZKnight
Oct 15, 2015 02:47 PM
6998poncho
Sep 25, 2015 02:56 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
rudolphschenker
Sep 4, 2015 02:41 AM
