Swap 9bolt disc to a 10 bolt?
Old Aug 27, 2006 | 12:51 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I was wondering can the disc break setup off a 9 bolt be swapped to a make a 10 bolt drum, into a disc rear??
Old Aug 27, 2006 | 01:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
quite sure it wont "just swap over"
Old Aug 27, 2006 | 02:26 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Yeah, I don't think it would be that easy. Then again the way it looks, it dont look that hard to do.I was wondering If anyone has done it before? I just want to be sure before a try to do this and maybe mess up the drum rear???
Old Aug 27, 2006 | 02:50 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The backing plates are different for the 9 & 10 bolt calipers.
Old Aug 27, 2006 | 03:52 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Yes, I noticed that, I think I would have to unbolt and use the back plate off the 9 bolt and try to bolt it on the 10 bolt?
Old Aug 27, 2006 | 03:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The backing plates are different on 9 bolts and 10 bolts, but that doesn't matter much since the drum rears have completely different axle flanges anyway. You could figure out a way to drill the drum rear to mount the 9 bolt plates.
Old Aug 27, 2006 | 07:19 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Yes, It seems like the axle flanges is the only thing that needs to be Modified on the 10 bolt. IT about 4 inches longer then the disc setup flange. I would have to cut it to the size of the disc flange,Then make the bottom hole bigger with 2 new top holes.
How does that sound? Any other info to reinsure me would be great!
Old Aug 28, 2006 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I assume you could drill holes for whatever backing plate you wish.
https://www.thirdgen.org/ls1reardisc
JamesC
Old Aug 28, 2006 | 09:03 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
JamesC
Thanks for that info!!
Old Aug 28, 2006 | 12:24 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
didnt see it was a 10 bolt drum rear you have to cut and drill the holes
Old Aug 28, 2006 | 04:41 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
sorry, i didnt get you?
Old Sep 7, 2006 | 06:45 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I ran into a couple of problems. I cant seem to figure out how to get the axle shafts out of the 9 bolt.i cant get to the backing plates off ? The 10 bolt was no problem. The other problem is the axle from the drums where the stud come out are bigger in diameter then the axles from the disc. I cant get the rotor to fit over the drum axles. Do I need to buy rotors for a 10 bolt disc to fit over these drum axles, or should I try to mod them to fit?
Help!
Old Sep 7, 2006 | 06:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Drum axles have larger flanges than disc axles, discs don't always fit right over them.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
