TC Lockup question
Old Sep 21, 2006 | 11:04 AM
kjvail1204's Avatar
700r4 on a carbed engine, need experts, HELP
Heres a breif history went from a 305 TBI to a 350 Carbed, no ECM. Now im having a problem shifting. Before you jump to any conclusions i just put ina new TC and Flexplate. Ive had my car this way sence Feb. and it shiftted fine. Now when i pull out on the TV or Detent cable the farther i pull it out the TC starts whinning and it still does not shift.
Is my TC already locked up cause it finally shifts when im doing about 30MPH and about 4K use to have perfect shifting points then all of a sudden it was red lining bewteen shifts thats why i replaced the TC.
I need help i need this car by friday, anyone at all.
Last edited by kjvail1204; Sep 25, 2006 at 07:21 PM. Reason: Tried all that and its not the problem, trying new people
Old Sep 21, 2006 | 11:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Did you ever put in a TC lock up switch in after you scrapped your computer?
Old Sep 21, 2006 | 11:46 AM
kjvail1204's Avatar
NO but thats the funny thing is it ran fine untill i f'd the TC the first time. Now it wont shift at all i mean can the TC lock on its own.
I guess what i need to know is what does the Tranny do if the TC is locked and you are in Stop and Go traffic.
Old Sep 21, 2006 | 11:54 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The TCC being locked will kill the motor when you stop in gear. Just like you would if you stopped with a manual with it still in gear and not pressing the clutch.
As for the TV cable (not a detent!) It has one and only one proper setting! Do a search you will find the process.
The TV cable controls the trannys shift points and line pressures, misadjusted it will cause goofy shifting and burn up a tranny in a real hurry. By pulling the cable like you did it makes the tranny think your going WOT all the time, thus the high shift points.
Old Sep 21, 2006 | 12:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not in a properly working 700R4.
Old Sep 21, 2006 | 12:09 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
What do you mean a properly working 700r4. I preety much in the same boat as kjvail1204 vbmenu_register("postmenu_3067570", true); . I just put in a 355ci and a new 700r4 with 3000stall.And i have been told I will fry the tranny without a tc lockup switch.
Old Sep 21, 2006 | 12:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unless there's a hydraulic problem with the transmission or it's been modified for a manual valvebody, the torque converter will not lock when the car is still.
The torque converter hydraulic circuit takes its pressure form the 2nd gear circuit, so it can only lock in 2nd gear or higher. When the car is stopped, the transmission is in 1st.
Old Sep 21, 2006 | 01:12 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
TCC has nothing to do with your shifting, auto trans. shifting are controlled by the gov., valve body, throttle pressure, or the ECM/PCM whatever you wanna call it.FYI
Old Sep 21, 2006 | 01:15 PM
screaminyellow's Avatar
Car: '91 RS/'89 Z-28
Engine: 305TBI RS/350TPI Z-28
Transmission: AOD's in both
Axle/Gears: 3.42 RS/ 3.73 Z-28
Sounds like either the TV cable is on set right or you did not install the torque converter right. When you put the converter in you should always check to make sure that you can spin the converter freely before you bolt it down, if not somthing is wrong!
Old Sep 21, 2006 | 01:23 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
So you guys are saying that there is no need for a tc lockup switch and nothing will happen to the converter or the tranny at all. And if thats the case why would anyone need a tc lockup switch?
Old Sep 21, 2006 | 01:26 PM
kjvail1204's Avatar
Ok the TC did turn freely, but now it takes it to really high RPM to shift. If i pull the TV cable out any the TC makes a whinning noise. I pretty much have to let off the Throttle in order for it to shift. Could there be something inside that is causing it to act this way.
Does anyone know how to wire the TC switch in. Not the kit you can order just to put a switch on plug that goes into the tranny.
Do i need to drop my pan and look for something inside.
Old Sep 21, 2006 | 01:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, that's not what's being said at all.
Old Sep 21, 2006 | 01:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the tech articles for instructions on how to install a manual switch in the ALDL.
Old Sep 21, 2006 | 02:16 PM
kjvail1204's Avatar
foudn the switch
Will this help my shifting problem or is there something internal i need to be looking at. Please dont tell me i need to rebuild my Tranny
Old Sep 21, 2006 | 03:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The TC has nothing to do with your shifting.
Check for a stuck governor maybe.
Old Sep 21, 2006 | 05:02 PM
Mr.Wolf's Avatar
Car: 87 Z28
when you put in your TC it should have clicked three times 1st time Input shaft,2nd time oil pump, 3rd stator. Yes theres a possibility you might have to rebuild, also check your fluid color and smell.
Old Sep 21, 2006 | 05:29 PM
kjvail1204's Avatar
New fluid but what am i looking for if its bad will it smell burnt, and two where is the govoner and what am i looking for there will it be stuck or covered in dirt
Old Sep 21, 2006 | 05:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The governor is under the round dome shaped cover on the side of the transmission.
Old Sep 21, 2006 | 06:29 PM
kjvail1204's Avatar
What am i looking for under there
Old Sep 21, 2006 | 09:10 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
pull the governor out with a twisting motion, it will come out with the tranny still in the car. move the flaps on the outside up and down and see it you can see the valve inside moving up and down
Old Sep 21, 2006 | 10:48 PM
Mr.Wolf's Avatar
Car: 87 Z28
just check the color and see if its a strawberry milk color if it is then it is time for an overhaul.
Old Sep 22, 2006 | 11:08 AM
kjvail1204's Avatar
That strawberry colored milk will it be in my governer if its that color its bad, but if its not then its ok i just have to look for the valve moving if its not moving do i jsut replace that or the whole governer or what.
Old Sep 22, 2006 | 11:20 AM
Mr.Wolf's Avatar
Car: 87 Z28
no, when you pull your tranny dipstick to check the level, check the color there. I haven't gotten that far in class as far as goverenors go. But trust me from experiece on teh TC and teh fluid color.
Old Sep 25, 2006 | 07:28 PM
kjvail1204's Avatar
tanny fluid is still red, I pulled the Gov. and i saw the two little seal thingies move top and bottom. the gear didnt turn but i figured it didnt have to.
I cleaned the Gov and pushed the TV cable all the way out and all the way back and still no change in the shifting, i took the plug off the side (three wire) do i have to do something to that, i cant remember if all the wires were cut when i started.
ALl i know is ive been driving it sence Feb without a ECU and then all of a sudden it would shift only at red line, I would left off the gas to get it to shift. I pulled the TC and there was metal in it so i got a new one, also got a new flex plate. The shifting problem is still the same. The tranny fluid was a darker color but it did not smell burnt. There was no large metal in the pan, just the little grey stuff. I dont think the tanny fluid had ever been changed.
When i had the shifting problem, there was tranny fluid coming all down the TC and off the front of the trany, i checked the front seal and its good.
Guys i dont wanna blow the tranny if thats not the issue. Ive only taken it a few blocka dn havent gone maybe over 20 for more than a 20 feet, it still wont shift.
anyone anyone at all
Old Sep 25, 2006 | 09:16 PM
Mr.Wolf's Avatar
Car: 87 Z28
your gonna have to have an overhaul done man, u said it yourself there was metal in the tc, time for rebuild.
Old Sep 26, 2006 | 04:15 PM
kjvail1204's Avatar
is this rebuild something i can do myself or do i need someone else to do it. Id love to save money cause i got a quote of 1000.00 and i can get a reman one with awarrenty for 1300.00
Old Sep 27, 2006 | 03:09 PM
Car: 87 trans am
as long as you have a clean area, a repair manual, and a bunch of patience, go for it, having the tools to do it is a big plus too.
Old Sep 27, 2006 | 03:22 PM
Mr.Wolf's Avatar
Car: 87 Z28
heres a quick question do you have a daily driver? other then your F-body, if so then go for it but get some practice in first on other trannys, so you'll have the experience on rebuilding a tranny, then rebuild yours. Otherwise take it to a shop and have it done if you have the money. me i'm going to school for autotransmissions and transaxles, and the stuff i'm learning is really helping me out understand how the transmission works, and what will cause it not to work. So i'd highly recomend if you can afford it go to school and learn about this stuff cause it can really help out in the future.
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
