Help My Iroc won't shift into park
No problems shifting shifter goes all the way forward into what the indicator says is park but it's still in gear can't get it up in to reverse either. Any ideas?
Thanks Sean
Thanks Sean
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
did you work on the car recently?
maybe the cable is bound, or damaged.
ive even seen a penny fall into the console and cause problems.
your questions is kinda vague. sorry.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
mine did the same thing when i first bought it and it was a loose bolt in the shifter lincage mounted to the trans pan check it out
Sorry for being vague. I knew I should have put more information in there but I was not sure what was needed I took apart the center console and could not find anything wrong so I came inside looked for some help here.
I have not ever worked on the tranny I've owned the car for a 6 months it is completely stock.
I crawled under it and the linkage that bolts to the pan is just hanging there both bolts are gone.
I found some bolts put it back in place and it works fine thanks for the Help.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
