Vss Speedo Gears
Old Oct 24, 2006 | 03:12 PM
ttopformula88's Avatar
Car: 1988 Formula
Axle/Gears: 3.73 Posi
Vss Speedo Gears
Can you use gears from a mechanical speedo in a VSS? Where would I get the speedo gears for a VSS?
Old Oct 24, 2006 | 05:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there is usually an add right over the posts for trasnmissioncenter.net they have it all.
Old Oct 24, 2006 | 09:43 PM
Car: 1988 Formula
sorry forgot to mention this is for a T-5.
Old Oct 25, 2006 | 03:30 AM
Pat Hall's Avatar
The T-5 mechanical gear and vss gear should be identical to each other. As long as they both attach to a metal shaft with the d-shaped end, they'll interchange.
Old Oct 29, 2006 | 04:20 PM
Car: 1988 Formula
What if I do not have the d-shaped end of the gear??
Old Oct 29, 2006 | 04:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some general info that might prove useful:
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Oct 30, 2006 | 01:03 AM
Pat Hall's Avatar
The post that James just put up should set you straight on what you need to get. The vss I just sent you has the metal shaft with the white gear on the end, identical to the one in the picture on James's post. You just need to get the same kind of gear with the correct number of teeth for the 3.73 ratio, which should be the red one with 21 teeth IIRC.
Old Nov 8, 2006 | 09:06 PM
Car: 1988 Formula
where can I find the P/N for the d-shaped gear for a 21 teeth ?
Old Nov 9, 2006 | 06:19 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
extensive searching.. i have a crapload of bookmarks on this somewhere.. good luck finding anything though because the only ones gm still has laying around is the 19 & 20 tooth i believe
if you had an auto you'd be fine, I dont know why there isnt anybody making gears for the t5 vss
Old Nov 9, 2006 | 09:31 PM
Car: 1988 Formula
Only problem is is that my auto the speedo gears are also wrong.
Old Nov 10, 2006 | 02:11 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Are you serious? I need the plastic D shaped gear with something like 24/25 teeth. Sheeit. I have a later T5 that is supposed to have this mechanical drive gear with the metal shaft/plastic gear. I substituted an old style housing with a 24T plastic gear and it works, but leaks. Crapcrapcrapcrapcrap. Here is the current gear/housing/shaft I need the 24/25 T replacement gear for.
So Nobody makes a 25 tooth gear for this metal shaft?
Old Nov 10, 2006 | 03:27 AM
Pat Hall's Avatar
I don't think I've seen anyone with a 25 tooth one. I think the highest one I've ever seen was a 23 tooth. Try D&D performance or 5speeds.com. One of these two places has some T5 speedo gears IIRC. Even if 5speeds.com doesn't have any, they could probably point you to a company that does.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
