Are 10 bolt axles tapered?
Old Dec 6, 2006 | 02:35 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I want to narrow my 10 bolt rear end and send my axles to Moser to have them shortened and resplined. This can be done to axles that are not tapered. Does anyone know if the 10 bolt axles are tapered?
Old Dec 6, 2006 | 03:02 PM
Shagwell's Avatar
Car: projects.......
They can't narrow stock c-clip axles, and yes they're tapered.
- Why would you spend the time and money narrowing a 7.5" 10-bolt?
Old Dec 6, 2006 | 03:42 PM
wesilva's Avatar
Transmission: 200R4
Darn....I was hoping they were not tapered.
Shagwell,
Thanks for the information. I am building a fairly hot Triumph TR7 with a 300 horsepower 4.3 Chevy V6 and 5 speed Tremec. I am using a rebuilt 10 bolt because I want to use some 3rd gen Camaro suspension pieces. A shortened Spohn Torque arm set-up, a custom panhard bar and control arms have been aquired and are in the plan. The plan is to basically duplicate a well executed 3rd/4th gen rear set-up. The 3rd gen rear alreadly has provisions for the torque arm. A well built 10 bolt will easily handle the 300 horsepower in a 2500 lb car but I need it shortened about 2" on both sides. I guess it's time to pony up for the custom sized axles.
Old Dec 6, 2006 | 07:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Even if they weren't tapered, you couldn't shorten them. You can't shorten a c-clip axle unless it was converted to c-clip eliminators and there isn't many of those available for the 7.5" 10 bolt.
New aftermarket axles are cheap. Just buy some Moser axles in whatever size/style you want. Providing you can even find someone to shorten the axles, it can cost almost as much as buying new axles.
My current 9" diff has Strange axles in it. My new narrowed 9" diff for my upcoming back half project has Moser axles. I like the Moser axles a lot more than the Strange axles.
Old Dec 6, 2006 | 11:42 PM
novatuc's Avatar
Car: 1984 Trans Am
Sorry, I have nothing productive to add to this post, but I just have to know why you can't shorten a c-clip axle. If he needs 2 inches shorter it seems you would just cut it, then machine a new spline and groove for the c-clip. I don't see the problem. I work in the aero industry so maybe this is normal to me.
Old Dec 7, 2006 | 10:21 AM
wesilva's Avatar
Transmission: 200R4
I don't know why either, novatuc. Assuming your axle is not tapered, Moser does the resplining and machining the groove for the C clip is a simple machining operation.
http://www.moserengineering.com/Page...pservices.html
Maybe someone will fill us in.
Old Dec 7, 2006 | 10:33 AM
Which would cost more than just buying new axles in the first place, except you'd get less; because instead of having nice new aftermarket performance axles, you'd just have some hacked-up worn-out old stock ones. Even weaker than they started out their life.
Old Dec 7, 2006 | 12:23 PM
wesilva's Avatar
Transmission: 200R4
Oh yeah...from a practical stand point, you are right. When Moser first started this service was cheap and forged axles were very pricey. It was more practical.
Were talking feasability from a machining stand point and not so much a practical reason why it wouldn't be done. I can't see why it couldn't be done from a machining stand point.
Old Dec 8, 2006 | 05:38 PM
islandRC's Avatar
just to let you know, i had a set from a '90 camaro shortened about 6" and resplined w/ c-clip grooves back in '00. at first i sent them to currie, but they couldn't do it and they then sent it over to moser. it cost $90. it worked well for the application. i sold that rear a few years back, but i know it is still running to this day.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
