Where is the best place....
Car: 1982 Z28
Transmission: 700-R4
Where is the best place to locate and buy a posi for my 82 z28, The Junkyard? Besides on here shipping charges are kind of high. Should I locate one in town and replace the gears and such? Any suggestions.....
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Purchase the appropriate posi unit and you can install it in the rear end you currently have in the car.
JamesC
JamesC
Check Jeg's. Auburn Gear. GM 7-1/2 and 7-5/8, 10-bolt, 26 spline. Part #'s 109-542057 (3.23 up) or 109-542058 (3.08 down), depending on gear ratio.
http://www.jegs.com/webapp/wcs/store...10002_13619_-1
Here's how to determinne what ratio the rear is (jerk the diff cover and look): numbers are stamped on the ring and pinion:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Car: 1982 Z28
Okay thanks for your help,
What about the gears do they have to be 26 spline also, cause I looked and I didn't find any that are 26 spline only 27....
The guy's at Randy's Ring and Pinion can also give you some good tips or advice. If you call them, ask about useing a solid pinion spacer instead of a crush sleeve. Works great.
http://www.ring-pinion.com
Pillsbry10
Aftermarket Product Review
62
Nov 12, 2011 10:45 AM
firechicken_3
Oct 8, 2009 05:10 PM
