700r4 problem
Old Jan 12, 2007 | 12:35 PM
topless 88's Avatar
Car: 88 iroc convert/87 formula/91 Z28
Engine: tpi 305/305 carb/305 tpi
Transmission: 700R4x3
Axle/Gears: 3:73/323/273
700r4 problem
OK, time to pick your collective brains. I just got my 88 iroc running again (motor swap) and drove it. The trans shifted fine and I put 15 or so miles on it. I parked the car for 1 hour and drove it again. This time I only had 1st gear. It woundn't shift into 2nd at all, and if I let off the throttle it goes to neutral. I put a tv cable on it and no change. BTW the motor is a stock 60,000 mile 305 with headers. Thanks for the help.
Old Jan 12, 2007 | 02:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You drove it without a TV cable?
Old Jan 12, 2007 | 03:30 PM
topless 88's Avatar
No, I replaced the cable. I should have said "put a NEW cable". I'm taking it to a trans guy tonight to have a new gov gear put in. Hope that fixes it.
Old Jan 13, 2007 | 12:31 AM
Pro Built Automatics's Avatar
The majority of times when you lose 2,3,4 all at once, it is usually the governor gear that is broken or stripped. Start there and see what you find.
Old Jan 18, 2007 | 01:07 PM
topless 88's Avatar
Thanks, the guy that I took the car to put a gov gear in it and STILL no change. Then we decided to put another new t/v cable on it. All this for a car thats going into storage in a couple of weeks.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
