tranny fluid leak?
Old Jan 12, 2007 | 12:37 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
tranny fluid leak?
noticed a lil pile of trans fluid on the garage floor last week,got a chance to check out the problem,its coming out between the balhousing and the transmission.is ther a seal in the front of the trans that i just just change someday i pull it off?
Old Jan 16, 2007 | 12:10 PM
xbcrguy182x's Avatar
First i would make sure its not the pan gasket. I had a similiar problem where the gasket wore out so badly, fluid would spray onto other places and it looked like fluid was dripping from other spots. Just something to keep in mind.
Old Jan 16, 2007 | 12:17 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You named it, the front seal. It is a wear item and will fail before a pan gasket.
Old Jan 16, 2007 | 01:06 PM
Interesting....my pan gasket failed already, i hope the front seal isnt next...*knocks on wood* Is that easy to do anyway?
Old Jan 16, 2007 | 01:18 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
right on right on,thanx for the feed back.was just checking so i can order a new seal b4 i spend the time to take it out.the only this that sux bout taking out the tranny is taking the console apart to take the shifter off .but ahh i wanted to cut my shifter a lil shorter anyway.
Old Jan 16, 2007 | 02:11 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Also check the trans cooler lines and the servo area for leaks.
Old Jan 16, 2007 | 02:40 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Yo dont need to take the shifter apart to take the trans out. Just disconnect the cable. Take the torque converter off. and wala! its right there.
Old Jan 16, 2007 | 03:22 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
if i had a atou thats what i would do,but i have a 5 speed
Old Aug 30, 2007 | 06:21 PM
camarohero's Avatar
Car: 1985 iroc
Engine: 5,328 cc 5.3 liters 8 V
Transmission: borg warner
Axle/Gears: 3:74
Re: tranny fluid leak?
yeah i had to take mine apart and it wasnt hard at all
Old Aug 30, 2007 | 10:11 PM
L69norm's Avatar
It might be leaking from the case at the countershaft bearing. Search on "T5" "stretched case" There's a bunch of threads you can read through to confirm the problem
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
