700r4 trans leak help!! also want 4th gear WOT shifts!!
Old Jan 14, 2007 | 02:33 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hey guys i have a quick question for ya all. im gettin ready to pull my 700r4 cus of a front pump seal is leakin i think. thrans fluid drips out of the tcc cover when the motor is runnin, i pulled the cover and it seems to be runnin around the coverter and flippin fluid on the trans case the drainin to the cover and drippin out.... i wanted to ask how bad is it to replace.....is it somthin i can do or is it best left to the pro? also while its out i was goin to install a part so i can have 4th gear wot shifts.....whats this part called, were can i get one, and is this somthin i can do or again is it best left for the pro? if its somthin i can do myself do you know were i can get some info or pics so i have an idea on how to do it....i wired up the trans for 4th gear lockup so i have been in the trans a couple time but i dont know to much about them. thanks for your time and help!! -ryan
Old Jan 14, 2007 | 08:44 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
You can do it. I prefer the superior valve.
Old Jan 14, 2007 | 10:55 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
GM part #8673948 (B-Car Fix) allows a full throttle upshift into OD. It is easy to install especially if you are installing a shift kit.
As for the pump seal, check the snout on the torque converter to make sure there is no groove worn into it, if there is a groove, the TC will have to be replaced along with the seal.
Both are easy jobs once the tranny is out.
EDIT: The "B-Car Fix" from the GM parts counter cost me $19 and some change. Also, your engine has to have the power to attain its shift point in third gear in order to upshift into 4th. My Trans Am shifted stock at 4500rpm with a 2.73 gear. That means I would have had to (car completely stock) get to 128 mph before it would upshift into 4th gear.
Old Jan 14, 2007 | 11:17 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The GM valve is discontinued and is now obsolete, unfortunately. I bought the last 8 valves that remained in dealers stock across the country.
They were a great value. GM always gets rid of the good stuff
Old Jan 14, 2007 | 11:20 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i prefer the transgo version of this modification but it requires removing the valve body.
Old Jan 15, 2007 | 11:26 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Well, I am glad I got mine when I did!
I purchased it 2 years ago, did they discontinue it recently?
Old Jan 15, 2007 | 08:04 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
About last september or so. I paid $35 or so for each one that I bought once shipping was factored in. Still a fair price considering what the aftermarket charges.
Old Jan 15, 2007 | 10:49 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup, I saw that the B&M piece retails for around $114.00 for basically the same part. Its
Old Jan 16, 2007 | 01:42 AM
Car: 92 1500p\u 2wd
and im guessin you dont have one you could sell me anymore do ya?
Old Jan 16, 2007 | 02:49 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Is this the same as the .500 Boost valve? I got one in this performance rebuild kit that i bought from Monster Transmission. I want my transmission to upshift a WOT.
Old Jan 16, 2007 | 06:32 PM
Car: 92 1500p\u 2wd
no its not the same thing....i have a .500boost valve and i dont have 4th wot shifts. i think the .500 valve raises line pressure so you get a stronger quicker shift!
Old Jan 16, 2007 | 08:38 PM
Pro Built Automatics's Avatar
You can make the changes to the TV plunger sleeve, without removing the valve body. You will need to block the two part throttle downshift holes in the TV plunger sleeve with two small allen screws. This will give you the 3-4 WOT shift, and will allow you to hold 4th gear at high speeds. The cost of two allen screws is about $0.34. You will need a dremel grind the allen screws to clear the bore and allow the plunger to move freely.
Old Jan 16, 2007 | 09:14 PM
Car: 92 1500p\u 2wd
I would like to try this idea first but i have a few qs for ya...if i do it this way i want to make sure its the right way....i dont want a allen screw to fall out in the trans!! do you have to tap threads for the allen screws in the plunger? also do you have anyidea what size screws work the best? almost free mods are always good!!
Old Jan 17, 2007 | 09:47 PM
67ss383's Avatar
Here's the TV plunger sleeve mod in detail. I plan on doing it when I do a rebuild.
http://www.joby.se/corvette/mods/2002-0X02_tranny_wot/
Old Jan 18, 2007 | 06:41 PM
Car: 92 1500p\u 2wd
perfect
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
