Rearend Question
Old Feb 13, 2007 | 12:53 PM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
Rearend Question
I have a 91 camaro RS 305 with stock rearend. I want to find some 3.73 gears for it. I've been looking on ebay for 3.73 gears. Theres quite a few to pick from, but whats got me confused is the number of splines. What am I looking for that will fit in perfect?
Old Feb 13, 2007 | 01:45 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Are you saying that you want to convert it from a single track to a limited slip? Or, are you just asking about swapping the pinion & gear?
Old Feb 13, 2007 | 01:59 PM
Car: 91 Camaro RS
Pinion and gear atm.
Old Feb 13, 2007 | 02:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No need to worry about splines if you're just getting gears.
Old Feb 13, 2007 | 02:07 PM
Car: 91 Camaro RS
When I read stuff like need a 3 seriers carrier, gets me all consued. So 3.73 gear for a gm 7.5-7.6 10bolt will fit then.
Old Feb 13, 2007 | 02:12 PM
Wadebryant's Avatar
Yes, 7.5 ten bolt.
Keep in mind that changing rear end gears may affect the speedo and the trans shift pattern.
Old Feb 13, 2007 | 02:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They'll fit if they're for the same series carrier as you already have.
Old Feb 13, 2007 | 02:25 PM
Car: 91 Camaro RS
What Carrier does mine have in it?
Old Feb 13, 2007 | 08:54 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
It will throw your speedo off big time...Mine is about 10 MPH of, and I went from 2.73 to 3.23......3.73 may be alot of gear, if you dont have a bit of a motor...I wish I would have went 3.42, instead of 3.23....3.73 woulda been to much for my motor tho.....BUT SOMEDAY..Good luck, Tom
Old Feb 13, 2007 | 10:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not if you replace the speedometer gears in the transmission with the correct ones.
Old Feb 13, 2007 | 10:51 PM
Car: 91 Camaro RS
Actually yeah the more I read the more im going towards 3.42 gears. But my biggest question is now, do i need to buy another carrier? 3 series? what did my rearend come with?
Old Feb 13, 2007 | 10:58 PM
92firebirdMT's Avatar
Car: 92 formula/86 z28
Engine: 406/ 350
Transmission: T5/700r4
Axle/Gears: 3.73 posi/3.23
look on your axle on the driverside toward the fornt and scrap off and look for a code.
I think if you have a 3.23 gears or above its a 3 series and if lower than that it a 2 series? correct me if I'm wrong.
Old Feb 13, 2007 | 11:02 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Factory you car would have came with 28 spline axles and a series 2 carrier. You'd either need series 2 gears or a series 3 carrier with series 3 gears. Typically factory carriers are series 2 with 3.08 and numerically lower gears. Series 3 usually are 3.23 and higher. I'd try and get a limited slip carrier along with those 3.42 gears.
Old Feb 13, 2007 | 11:22 PM
Car: 91 Camaro RS
Okay thats what I figured but wasn't sure. all!
Old Feb 14, 2007 | 03:15 AM
ede's Avatar
ede
you can buy gears to fit either series carrier or you can use a spacer on the ring gear to keep from replacing the carrier to match the gears
Old Feb 14, 2007 | 07:26 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Apeiron, you are right about that...........
It might be easier to do the whole rear, I just got a 3.23 posi, with disc brakes for 300....Cleaned it up, painted it...Chjecked it out, changed the lube, and am burning both wheels now...Me, and my buddy did it in 8 hours....No fancy tools or workspace, and we are both almost 50......I spent probably 25, or 30 on parts to get it in, plus all the "goody" stuff, I thru in.I didnt want to jack with setting up a gear, and all the other stuff.....Tom
Last edited by Gallileo60; Feb 14, 2007 at 07:30 AM. Reason: Automerged Doublepost
Old Feb 21, 2007 | 11:20 PM
Car: 91 Camaro RS
Just an update. I found a set of 3.42 gears and eaton locker for cheap. They are being shipped to me right now. Am I gonna need anything besides diffrential oil when putting it all back together?
Old Feb 21, 2007 | 11:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you sure the locker is a good idea?
Old Feb 25, 2007 | 03:50 AM
Pat Hall's Avatar
If it's an Eaton Gov-Loc unit, I'd avoid it. They're nicknamed "Grenade Lock" since they're weak and have a tendecy to actually explode into pieces when they lock up on dry pavement under power. You really ought to consider an Eaton clutch style posi, or at the least, a factory Auburn posi unit. The Eaton clutch posi is pretty expensive, but you can usually locate a factory Auburn one in decent used condition for cheap. Firechicken has a 3 series one for sale right now on the engine/drivetrain section of the classifieds.
Old Feb 25, 2007 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Couple of pups .
JamesC
Old Feb 25, 2007 | 06:25 AM
ede's Avatar
ede
you'll need to right tools, depth gage or pinion setting tool, dial type in/lb torque wrench, ft/lb torque wrench, indicator and mag base, bearing splitter, press, 0-1 mic or caliper, "special tool to hold the yoke or you can hack it up with a pipe wrench, and a manual showing you what to do. you also need the specs for the gear set if they aren't etched on the gears try a .035 shim on the pinion and .008 to .012 back lash. set the pinion preload to 25-30 in/lbs with new bearings.
Old Mar 3, 2007 | 09:30 PM
Car: 91 Camaro RS
3.42's and eaton locker installed. Working perfect. I also put on new brakes and seals. Drove it around the block few times to break the new bearings in then went out for a test. I took off from about 10mph roll had the tires chirping when shifting. Then floored it from dead stop left 2 big posi black marks, i'll take pictures tomorrow and post um. guys.
Old Mar 4, 2007 | 12:30 PM
Car: 91 Camaro RS
Old Mar 4, 2007 | 07:30 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Nice power brake...
Old Mar 5, 2007 | 11:19 AM
Car: 91 Camaro RS
Nah, after the tires were spinning I was off the brake instantly. Once I hit 3rd gear I ran out of motor.
Old Mar 6, 2007 | 08:04 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Damn now you gotta get it to hook up........
Old Mar 6, 2007 | 09:30 PM
Car: 91 Camaro RS
I need to get new sway bar bushings, the sway bar is just hanging. I was gonna fix it when I had the car on jacks but I forgot to buy them and I just wanted to get it done.
My speedo is off by 10mph exactly. Followed the rents they were doing 55mph and my speedo was reading 65mph. I need to follow them at lower speeds, I swear to god when it says i'm doing 40mph, which means I should actually be doing 30mph it sure doesn't feel like it. It can't be 10mph off, maybe at speeds above 50 but not lower than that. Weird
Old Mar 7, 2007 | 03:27 AM
Pat Hall's Avatar
That's exactly how the speedo behaves when it's off. Mine gets thrown off during the winter months because I run 70 series snow tires. It's pretty close to accurate at lower speeds, but the faster you go, the more it's off. It's an exponential effect. Do you still have the stock 305 TBI in your car? If so, that's quite impressive to be able to grab rubber all the way through 3rd gear. In fact, it's kinda hard to believe actually.
Old Mar 7, 2007 | 10:37 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
as long as your happy man thats what counts, i have 3.73s and really wish i had went with 4.10s,
Old Mar 7, 2007 | 02:21 PM
Car: 91 Camaro RS
I got the 305 out of a iroc-z. Just needed top end rebuild, put stock parts back in. So far I've added optima red top, under drive pulley, moroso 8mm blue max wires, and bigger rocker arms. I've got an open air element and k&n filter on the way.
BTW, it was a blacktop road.
Old Mar 7, 2007 | 10:46 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
dude I never seen no 305 burn that much rubber with that gear...It looks good, but it aint.....I love how my hooks up, even tho it runs a sick 15.....I will change that this week...14's here I come.....More gear, more motor....YES......
Old Mar 8, 2007 | 03:35 PM
Car: 91 Camaro RS
This was from a digital camera so quality isn't great.
Old Mar 8, 2007 | 06:33 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Good looking car.....
Old Mar 8, 2007 | 09:23 PM
Car: 91 Camaro RS
Just don't look too closely . It needs a paint job bad, the people who owned it before me lived on a farm and gravel road, you can tell its been repainted. Whoever repainted it did a cruddy job. I got all the equipment to paint mine myself, just don't have the money to buy all the paint. And theres still parts I want to get, like fiberglass hood with 2" or 4" cowl, z28 spoiler, probably new ground effects.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
