those with high performance rebuilt 700-r4, what do you run in it?
Old Feb 18, 2007 | 11:46 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i see mobil1 synth atf at wal mart, $6 a qt.................red line, royal purple, lucas and the like any better?
Old Feb 19, 2007 | 03:29 PM
wasp's Avatar
bueller?
Old Feb 19, 2007 | 04:46 PM
wasp's Avatar
can this be used in a 700-r4? i see a disclaimer at bottom
https://www.amsoil.com/storefront/art.aspx
Old Feb 19, 2007 | 05:36 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I use whatever is cheap. My first 10 second run had wal-mart atf in the pan.
Old Feb 19, 2007 | 05:59 PM
wasp's Avatar
it shifts real hard using b&m, will this be lost switching amsoil, redline, or any other synthetic?
Old Feb 19, 2007 | 06:11 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
More than likely yes. Unless they have changed it, the B&M fluid is not compatable with lock up converters.
I personally have had odd, unexplained failures in transmissions that used synthetic. Therefore, I won't use them.
Old Feb 19, 2007 | 07:25 PM
wasp's Avatar
ok, dumb question, ive been using it a while now, therefore i dont have a lockup converter?
Old Feb 19, 2007 | 07:42 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
You have a lock up converter or a non lock up converter. Only the guy who sold you the converter can answer that. 700r4's all come with lock up style converters. Most continue to use the lock up style. Some choose to install a non lock up converter. The pump must be modified to do this(non lock up) properly.
Old Feb 19, 2007 | 07:50 PM
wasp's Avatar
yeah , well i wrote the guys that built my tranny, level 10 in jersey,http://www.levelten.com/ to see what they have to say about fluid................at this point im leaning towards keeping the b&m...........i think they work in either kind btw................http://www.bmracing.com/index.php?id=faq
see #14
Old Feb 19, 2007 | 08:17 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
They must have changed it. Last time I read the label on the bottle it said not to use it for lock up converters. Guys have been using it for years though.
In my origional post about the B&M, I started the sentence with "unless they changed it"
Old Feb 19, 2007 | 08:28 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Hmm, interesting thread......
Old Feb 20, 2007 | 12:16 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I use the wal-mart brand dex 3 atf, tranny works fine.
Old Feb 20, 2007 | 03:30 PM
wasp's Avatar
welp, level 10 says they either run chrysler multi, which ive never heard of, or what the manufacturer states.................
Old Mar 26, 2007 | 09:37 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: those with high performance rebuilt 700-r4, what do you run in it?
Cheap Wal Mart ATF in my built TH350 hasn't been changed after the 200 miles like I was supposed to; fluid is still clean and trans shifts fine. I bought Castrol ATF this time just to not be so cheap.
Old Mar 27, 2007 | 01:26 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i run coastal atf in mine.
Old Mar 27, 2007 | 05:32 PM
toms84ss's Avatar
Valvoline.
Old Mar 27, 2007 | 05:41 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
mine came filled up with mobil synthetic from gearstar along with a couple quarts to top off.
Old Mar 27, 2007 | 06:14 PM
HPE's Avatar
HPE
Since I used to be good friends for years with Jimmy Gilante who ran then owned Darrell Youngs Racing transmissions for years- He always told me not to put anythiung into it other than regular DexronIII tranny fluid- No sythetics, no additive crap. My traninies have always worked great with just off the counter stuff.
Its not about what you run, but more mainly about the temp it runs. If it is too hot them make sure you have enough volume and a good cooler.
Old Mar 31, 2007 | 01:13 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I run the old type "F" and have no problems whatsoever running it in GM transmissions. I like the type "F" because it has extra friction modifier that makes the clutches hit a little harder and stick better.
It doesn't affect my lock up, either.
Old Apr 1, 2007 | 02:49 PM
MdFormula350's Avatar
Just basic Dex 3.
Old Apr 1, 2007 | 06:23 PM
Gramps's Avatar
Car: 87 Camaro IROC
most trans shops will suggest trick-flo ATF for your high-performance auto trans. if you want to be cheap, you can just run the normal stuff, but your bands and clutches will wear out faster and your converter may not lock up well because conventional oil cannot handle the amount of heat put out. and PLEASE change your oil when its due.
Old Apr 2, 2007 | 08:02 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I am about to change the oil in my 700 and was looking for Dex3 but on my oilstick it says "use only Dexron II"......the fun thing is that i have some 4 imperial gallons of Dex II in the garage could i use it or not
I thought 700 box was only to be fed with Dex3 !?
By the way i have the original lock up converter.
thx Mats
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
Bradsaundry
Aug 12, 2015 12:34 AM
