where can i get this tool?
Old Feb 18, 2007 | 06:46 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
in/lb torque wrench
Old Feb 18, 2007 | 06:54 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Sears auto zone shucks etc. They will have one.
Old Feb 18, 2007 | 07:04 PM
toms84ss's Avatar
I got mine from Matco.
Old Feb 18, 2007 | 07:08 PM
rjmcgee's Avatar
Clicker or beam style?
If it's for checking the preload on something like a pinion bearing you'll need the beam style torque wrench. I know that when I set up the gears in my car it was pretty hard to find one without going with the snap on guy and that was just too many $'s for something I rarely use. I would watch Ebay.
Old Feb 18, 2007 | 11:39 PM
Pat Hall's Avatar
I wanted a nice one, but buying it new from Snap-On was really expensive. I watched Ebay auctions and ended up getting a barely used Snap-On with the dial gauge for about 1/3 of what they cost brand new. I mainly bought it for setting the preload on pinion bearings, and it works excellent for that purpose. Just make sure you don't get a click type if this is what you're buying one for. You'll want a pointer or dial gauge style so you can watch the resistance as you rotate the pinion.
Old Feb 19, 2007 | 04:15 PM
toms84ss's Avatar
Mine is beam style.
Old Feb 19, 2007 | 04:20 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
If you plan on using it for checking rotating torque (like setting up a rear end etc.) you will want a dial type. While a dial type can be used for tightening bolts, a clicker is the style of choice in that situation.
While the name brands do cost more, I have found it is a matter of getting what you pay for, if it says "Made in China" buy two (it is still probably cheaper than a domestic) in hopes one will work and maybe they will average an accurate reading.
I'd rather have a used Snap-On or Mac, than a new "Made in China"
Good luck
Last edited by TexasSilhouette; Feb 19, 2007 at 04:23 PM. Reason: Corrected crappy typing
Old Feb 20, 2007 | 03:09 AM
ede's Avatar
ede
i have several dial types and a couple of click types, all from snap on.
92projectcamaro
Dec 8, 2015 12:25 AM
tyeo098
Nov 30, 2015 06:27 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
