Stall speed of Suburban 2wd 700R4 converter?
Car: 2000 BMW M5
Hi guys, does anyone know the stall speed of a stock 91 suburban 700R4 2wd "medium stall" converter? I just picked up a gm factory replacement 700R4 with only 1 year use on it for $100 w/ converter. If the converter is 2400 stall or thereabouts I might use it. Anyone know? I couldn't find a real stall # listing for this unit. I have the part # from the label on it, it is DCNF 2420 6164
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stall speed of Suburban 2wd 700R4 converter?
I doubt it's that high. Full size truck converters stall very low to use torque effectively. It's probably 1200-1500 at the most. 1800 would be an extreme for a factory converter.
Car: 2000 BMW M5
Thats what I figured, I was dreaming that I wouldn't have to buy a converter. Dammit!! In the trash it goes.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
1100 is stock, 1300 is the towing stall. Pretty much worthless from a performance perspective. You can buy a 1998 2wd s10 4.3L stall and install that in your car for a cheap 2200 stall that you can buy from any parts store in the country.
Car: 1983 G20 Chevy
Transmission: 4L60
The diesel converters are 1100-1200 rpm stall. The medium stall converters stall right at 1,400-1,600.
Car: 87 IROC L98
Stall speed is only one factor of a converter. You can have an 11, 12 and 13" converter all stall at the same speed and they'll all react differently. Internally, a converter has a multiplier. A different multiplier ratio and the converter will perform differently. Just trying to find a factory replacement converter to use as a performance converter is a waste of money. The rated stall speed of a converter is also an estimate. A converter that stalls at 2200 behind one engine may stall at 2500 behind another or 1800 behind another. It all depends on how much torque is being put into the converter.
Torque converters are one thing that you can actually say the more expensive ones are better and you get what you paid for. The 8" race converter in my car is worth close to $1000.
Stall speed on a GM DCNF 2420 6164 torque converter is 2075 RPM.
http://www.e-digitaleditions.com/i/4...15-catalog/105
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
1992 Trans Am
May 10, 2023 07:19 PM
