what gears are in my car?
Old Apr 2, 2007 | 12:45 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
i have a 1991 camaro rs hard top that had a v6 3.1 engine in it, how do i find out what gear ratio rear end is in it? its also a 1 legger, and i put a 350 in it would like to upgrade to posi but not sure what gear ratio is in the v6 setup
Old Apr 2, 2007 | 12:52 PM
Re: what gears are in my car?
You look at it while you're replacing the fluid, like needs to be done.
Old Apr 2, 2007 | 05:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Only the RS and the Firebird in 1991 were offered the 3.1L V6.
The manual transmission cars got 3.42 gears. Automatic transmission cars got 3.23 gears.
Looks like yours has 3.23 gears.
Old Apr 3, 2007 | 03:12 AM
tourville's Avatar
Car: 1991 Camaro RS
sweet, then no need for the "upgrade" i suppose, is it easy to make it posi? what do i have to do?
thanks
Old Apr 3, 2007 | 09:34 AM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
if i was u i would just go to a junk yard and get a rear axle off of a v8 cars. i had a friend who put a 350 in to his car and had a 3.8L rear end. well the out come of that was he had to change the fluids on it ever two week or so. that and ur better off doing so just for the fact that the v8 rear end can hold more torq then a v6
Old Apr 3, 2007 | 09:42 AM
Really!?!?!?!?! How so?
They are absolutely identical in every way, part number for part number; except of course for the 9-bolt in some V8 cars, which doesn't apply to the model year in question.
The only differences are posi (the 6-cyl cars never got it, but a few of the V8 ones did) and brakes (the 6-cyl cars are all drums, but some V8s got discs).
Old Apr 3, 2007 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The main difference between a V6 and V8 diff is the gear ratio offered for each. Other than that there is no such thing as a V8 or V6 diff.
Old Apr 4, 2007 | 02:04 AM
tourville's Avatar
Car: 1991 Camaro RS
what do i have to do to change my rear end over to posi?
hectre13
Dec 11, 2023 08:14 AM
specialized
Jun 18, 2022 09:26 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
