TCC dead.How do I replace?
Old Apr 14, 2007 | 10:51 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I've been having a problem with my TCC solenoid as of late.If I leave it plugged in.(I have a quick disconnect with the tan-black wire that runs it)My car bogs down badly and the TC locks up WAY to soon.If I leave it unplugged the car drives fine.I would like to know how I can replace it.I know it's in the tranny pan but I'm alittle leary of anything tranny wise.Also another question I have is is there a way I can modify the trans so that I wouldn't need the lockup.I know I would need a different TC but that's not a big deal.I live in a small town so highway mileage isn't that big a deal. Help me out guys!
Old Apr 14, 2007 | 11:40 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: TCC dead.How do I replace?
take it to a tranny shop. might not cost too much to fix.
Or put a big cooler on the front and forget about it.
Old Apr 14, 2007 | 11:46 AM
I already have a tranny cooler,it's in my sig.
Old Apr 14, 2007 | 04:53 PM
anybody else? i could really use some help here.
Old Apr 15, 2007 | 04:46 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
what are you looking for someone to say? your tranny needs more troubleshooting. dig in or pay out. To change converters you will pull the tranny out anyway. fix it right or just drive it.
Old Apr 15, 2007 | 02:30 PM
Vince @ FLT's Avatar
You might not have a trans problem but motor/drivability problem. The tc locks up and puts more of a load on your motor. Just my opinion. You should have someone take a look at it.
Old Apr 15, 2007 | 05:36 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I'm sorry no one has given you any kind of valuable answer yet. I also have a 700R4 with a bad TCC solenoid, that locks up immediately when 2nd gear comes on, and bogs the motor down so bad you can barely drive the car. With it disconnected the car drives totally fine.
Old Apr 15, 2007 | 07:07 PM
327 TPI- FWIW The 700 uses second gear feed oil for the lock up circuit. In your case from what you described it definitely sounds like you have a transmission issue. You might want to try replacing the tcc solenoid and have the valve body serviced. First thing to do is to put a scan tool on your vehicle that has data capabilities. Look to the tcc command. When you car hits second and starts to bog down what does the scan tool data tell us? Is it sending the ground signal to the transmission? If not and it still feels like the converter is locking then you probably have a cross leak in the pump or in the valve body of the transmission. Good luck
Old Apr 19, 2007 | 11:00 PM
Ok what you guys have told me is good but my original questions have yet to be answered.How do I replace the TCC solenoid and if not how can I modify my transmission so I can "delete" it.As stated I would need a different converter and possibly tuning it out of the ecm.So any help on these issues would be great.
Old Apr 21, 2007 | 07:54 AM
If you are looking tho eliminate the tcc function you will need a different converter and also you will have to modify the pump. There is a kit made by trans go that gives you a new valve to be installed in the pump where the lu solenoid goes. This modification is very important for proper lube with a dummy lock converter. As far as replacing your factory solenoid, You will have to drop the pan and remove the 2 bolts that attach it to the case. It is located in the front of the pan area and the snout of the solenoid is inserted into the pump.
Old Apr 21, 2007 | 11:38 AM
thank you,that was exactly what I was looking for.
jklein337
Sep 19, 2018 06:23 PM
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
