700R4 Question
Old Apr 23, 2007 | 05:04 PM
ReverendZ28's Avatar
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
700R4 Question
Do you know if the Vin number would tell you if you had a 700R4 if not anyone know where to look on the trnny??? Thanks -Rev
Old Apr 23, 2007 | 05:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 Question
The VIN only encodes the engine, not the transmission. If your car had an automatic after 1984, and it's not a TTA, then it has a 700R4.
Old Apr 23, 2007 | 05:31 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
Re: 700R4 Question
my 84 has an automatic and it has a 700r4....doesnt it?....
Old Apr 23, 2007 | 05:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700R4 Question
If it's a 4 speed, yes. The 700R4 was available earlier, but after about 1984 there were no other automatics available, except in the TTA.
Old Apr 24, 2007 | 05:00 PM
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Re: 700R4 Question
Thanks that makes me feel alittle better lol, I took it in to a transmission guy to ahve it looked and he said it wasnt a 700R4, I tought he might be full of it cause when I asked a buddy o mine, his pops has been a mechanic for well over 34 yrs, said that I sould becareful alot of times self owned bussiness like the one I went to will swap out the 700R4 cause they are "bullet proof" transmissions. I said I would get a second opinion. Havnt gone anywhere yet, but got to thinking if there was a way I could be sure it was a 700R4. casting numbers ext... Thanks again! -Rev
Old Apr 24, 2007 | 05:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700R4 Question
The 700R4 actually has a reputation of being anything but bulletproof.
Check the shape of the transmission pan to identify it:
Old Apr 25, 2007 | 04:55 AM
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Re: 700R4 Question
Really what kinda of problems are they related to... I always got the impression from most of my thirdgen comrades back home that they were solid and "bullet proof" lol. Well thanks Ill go n take a look under the car in the mornin see what im workin for... This might sound kinda dumb but know what kinda trans fluid it uses? Everyone I talk to says somethin diff... Also I have a buddy with a 87' 4spd a/t and was wonderin did they also come with the 700R4 or did that only come with the V8's-Rev
Old Apr 25, 2007 | 11:15 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700R4 Question
All the 4 speed automatics are 700R4s, except in the TTA.
Old Apr 25, 2007 | 09:40 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: 700R4 Question
if your runnin stock setup and you drive your car good then itll last a long time. but the same goes for any trans.
in like 91, they changed the name of the 700r4 to a 4l60, then came out with the 4l60e. if you go to a trans shop, very rarely will they sell you a 700-r4 part, it will be a 4l60 part. so if the guy meant it was a 4l60, he would be wrong, but not far off.
but nevertheless...if he cant identify a 700r4, and wont believe you when you tell him...then he's useless and you should find a smarter trans shop.
Old May 5, 2007 | 02:15 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Re: 700R4 Question
Indeed!
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
