rear end/ locker problem
Old Apr 25, 2007 | 10:03 PM
Jap408Cracker's Avatar
Car: 87 IrocZ/87 Iroc Z28
Engine: L98 350 TPI/ LT1 350
Transmission: BW T5 5spd/ 700r4 A4
Axle/Gears: 10 bolt posi 4.10/10 bolt posi 3.73
whats up guys... i built my rear end about 4k ago and now i think its bugging out. 10 bolt posi, 4.10 gears, toms axel, detroit locker. whenever i take a turn slow or flip a b!tch i feel and hear grinding (sounds like a ratchet), but was told thats normal. is it? every now and then i feel this big pop and feel my right wheel kind of lock up. is this just my locker slipping? i opened it up but saw nothing, but when i jacked it up and spun the passenger tire backwards, it made some grinding sounds. you guys have any ideas?
nick
Old Apr 26, 2007 | 04:52 PM
Shagwell's Avatar
Car: projects.......
Re: rear end/ locker problem
For the cost of some fluid pull the cover. It's the only way you will ever know for sure. - Anyhow, a locker in a 10-bolt is a bad idea.
Old Apr 26, 2007 | 06:37 PM
i pulled the cover off, but didnt see anything. i realized this problem only happens when im in gear, when i throw it in neutral theres no problem. anything?
Old Apr 26, 2007 | 07:39 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
sounds like a locker
Old Apr 26, 2007 | 08:46 PM
so this is normal??
Old Apr 27, 2007 | 05:35 PM
"most" lockers make noise during normal use, some are a lot louder than others. you need to find someone who has had experience with your particular locker and compare notes, or take it to a driveline shop and have it looked at if it's really stressing you out. my powertrax makes passengers ask me "what the hell as that noise?" all the time.
one question for you: how is it both?
"10 bolt posi, 4.10 gears, toms axel, detroit locker"
Last edited by 1989formula355; Apr 27, 2007 at 05:37 PM. Reason: Automerged Doublepost
Old Apr 27, 2007 | 05:45 PM
alright man, thanks...
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
IroczFan
Oct 6, 2015 10:13 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
novaderrik
Aug 10, 2015 12:44 PM
