weird clutch slipping problem
Old Apr 30, 2007 | 03:06 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
First off, i swapped a t-56 with a centerforce dual friction clutch in my camaro and everything seemed to work fine. It takes off alright other than the clutch ingaging at the top ( only have to push it down an inch to shift). The problem im having is when i am cruising in any gear and hit the gas a bit the rpms go up and the car doesnt go any faster, what would cause this? Im having no problem under light driving, i just cannot get on it or it slips.
Old Apr 30, 2007 | 06:06 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: weird clutch slipping problem
Basically, you have no freeplay.
In my '70 GTO this happened if the pivot ball in the clutch housing is too long putting constant pressure on the pressure plate. Another cause for it is if your clutch arm was installed into the throw-out bearing incorrectly.
I couldn't tell you if your car has the same issues, but if it's driven too long like this, your throw-out bearing will not be long for this world.
Old Apr 30, 2007 | 06:38 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
This was a setup somebody else was using and it worked fine for them. Im 99.9% sure it's all put together right, fork, TO bearing and all. The only thing im concerned about is the clutch plate. What would happen if it is installed on the pressure plate on the wrong side? I took it all apart and i cannot remember if i put it back on right, hope so. Would oil dripping from the back of the motor get on the clutch and make it slip? I dont have a dust cover.
Old May 1, 2007 | 07:18 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
So if i put spacers on the bolts that connect the slave and bellhousing to loosen the tension, will it actually help or will the hydraulics compensate for the changes? From what ive read the hydraulics will make up for whatever changes where done.
Old May 1, 2007 | 07:23 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
Is the fork completely relaxed without the slave cylinder attached?
If not, it needs to be.
Old May 1, 2007 | 10:52 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
yeah it is but when i draw the slave up with the bolts it puts tension on the fork. Is there supposed to be 0 tension on the fork when the slave is attached?
Old May 2, 2007 | 12:03 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
Yes. It must be relaxed with the slave bolted up. If it isn't, your fork pivot ball (screws in back of bellhousing) may be too long. They're replaceable, but you'll likely need to pull the bellhousing to do it which means pulling the trans.
Old May 3, 2007 | 09:15 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
If the fork is relaxed wouldnt it be possible that it could fall out of the TO bearing? I figured there is supposed to be a little bit of pressure to hold the fork in place?
Old May 3, 2007 | 10:47 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I'm gonna post this before sofakingdom does.
Not saying it will fix your particular problem, but it has helped SO many others in the past, whether they admit it or not! Including myself.
Attached Thumbnails weird clutch slipping problem-throwout-20bearing-20assembly.jpg
Old May 4, 2007 | 11:17 AM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
Not if it's clicked onto the pivot ball correctly.
Cleotiz
Jan 6, 2018 08:56 PM
maroe624
Apr 16, 2017 08:29 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
CORV3TT3
Aug 23, 2015 11:26 AM
