700-R4 TV cable question
Old Jul 23, 2007 | 03:05 PM
abuckley1290's Avatar
ive been researching about the tv cable and i made kind of a space out of a zip tie( pic attatched)..i like the way it shifts but is this safe for the transmission?
Old Jul 23, 2007 | 04:51 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 700-R4 TV cable question
If this was to fix a broken TV cable, it should only be a temp fix. Auto parts stores sell a little part in the HELP section that has a threaded barrel, with a hole for the wire to insert and a screw to clamp down. That would be safer. If this is to re-program shifting, you need to re-educate yourself on what the TV is for. bowtieoverdrives.com is a good tech source. TV made EZ is their tech pages on the topic.
Old Jul 23, 2007 | 05:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You haven't actually done anything useful there. As soon as you go to WOT the cable is going to ratchet out as it should to bring itself back to the one, and only one, correct setting.
Old Jul 23, 2007 | 05:31 PM
okay thanks thats why i was asking, i just liked the way it seemed to shift with that. Is there anyway it can go out of adjustment if its never been touched from the factory? Thanks
Old Jul 23, 2007 | 06:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The cable could "stretch" over time, but resetting it would fix that.
Old Jul 23, 2007 | 06:39 PM
ok thanks one more question..i cant get the button to go in. I tried pushing it as hard as i can and using a screw driver but no luck.
Old Jul 23, 2007 | 08:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't go in very far.
Old Jul 23, 2007 | 11:49 PM
Pro Built Automatics's Avatar
You could use the Sonnax (AS1-01K-1) TV corrector here. It will collapse when you reach WOT and not let the TV cable come out of adjustment, and allow normal shifts at light throttle openings.
Old Jul 24, 2007 | 07:51 PM
i know the ziptie is not the proper method to adjust the tv cable, but without it it's shifting too early and is very hard to get it to downshift. With the ziptie, its shortening the cable raising the shift point and etc. Also, it has not ratcheted out with the ziptie in place at WOT...i just want to know if it is safe because it feels perfect when im driving. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
